What is this sensor (pics)
Old Jan 18, 2007 | 02:34 PM
callmej75's Avatar
The temp sensor is far right, beside that is the cold start injector time switch, the other 2 is I have no clue...
Old Jan 18, 2007 | 02:43 PM
CEbeling's Avatar
Originally Posted by thook
Hmmm.....sounds like what mine did before I replaced the ECT...the idle bouncing that is. The temp gauge is probably your thermostat. Pull the broken sensor out and see if it's kinda greenish and rusty.
Oh! And to pull the codes, there's two terminals on the diagnostic thingy at the passenger side wheel well. It's a little grey box with a flip up lid. I think the terminals are TE1 and E1, but that's probably wrong. There's threads on pulling the codes, anway. You just have to jumper the two correct terminals with a wire or paper clip, turn the key on to ignition, and the check engine light will flash a certain number of times.
Better yet, here's the link..
http://www.off-road.com/toyota/tech/codes/index.html
Its green and rusty. Sounds like we have a hit. I am going to call the stealership and see if the have one.....
Old Jan 18, 2007 | 02:47 PM
thook's Avatar
Check on a thermostat while your at it! And if your up for it, a cooling system flush may not be a bad idea.
Old Jan 18, 2007 | 03:36 PM
CEbeling's Avatar
Thanks Thook, your advice was extreemly helpful!!! This is the little trouble maker.. I just went out and baught one for $70.00 at the stealership.
The cooling system got replaced as well as the engine. I did all preventative maintenance including new hoses cooling and thermostat.
Old Feb 3, 2007 | 04:23 PM
  #25
Chapman88SR5's Avatar
so what sensor was it?
Old Feb 3, 2007 | 05:23 PM
  #26
JamesD's Avatar
It looks like the ECM coolant temp sensor or it is the one for the overdrive on A/T transmissions. What it does is reads the coolant temp and prevents the transmission from going into O/D until a certain temperature. So basically their is two coolant temp sensors. I believe the black is for the transmission and the green for the engine but I could have them vice-versa.
James
Old Feb 3, 2007 | 05:26 PM
  #27
JamesD's Avatar
From this picture:
From left to right: temp gauge, engine coolant, trans temp coolant, and temp idiot light. I may have them mixed up but I think I'am correct.
James
krimsonone
Sep 13, 2024 09:33 AM
okamikai
Apr 30, 2018 10:19 PM
raptor510
Aug 19, 2015 02:15 PM
nonstop
Jul 24, 2015 06:29 PM
bryan34w
Jul 6, 2015 05:53 PM
