BVSV (Bimetallic Vacuum Switching Valve)
Old Jan 24, 2007 | 10:24 PM
Ebin's Avatar
Angry BVSV (Bimetallic Vacuum Switching Valve)
During the course of doing a HG replacement I broke the old BVSV breaking it down and I broke the new one putting it back together (yes, I know I am a Dumbass). I think I understand what this valve does. How critical is this valve and can I get by without for the time being (winter time and all). If I just install it with no vacuum lines hooked to it? Why would they design this part with the tips so easy to break off? (rhetorrical question)
Old Jan 25, 2007 | 09:57 AM
BC Rider's Avatar
Ebin:
If this is the BVSV that runs the canister purge it should be fine without it. IIRC it is just to control evaporation emmisions when parked. However, I would block off the ports to help ensure you don't end up with vacuum leak.
Old Jan 26, 2007 | 01:13 AM
the_supernerd's Avatar
I am not sure about the V6, but on a 22R there is a BVSV controls the EGR. Running without the EGR will cause pinging. If you are not going to get a good BVSV, then you would probably be better off attaching the hoses together so the EGR works all the time instead of not at all.
Edit: I just looked up the 3vze manual on Autozone.com and I noticed that the BVSV controls flow to the charcoal canister like BC_Rider said. He is right, just plug the vacuum line and you will be fine.
Old Mar 19, 2026 | 07:12 PM
BrattyBrat's Avatar
So does this mean I can delete it permanently? And should I plug the two vacuum lines or connect the two together?
Old Mar 21, 2026 | 04:58 AM
scope103's Avatar
If you block off the BVSV, the tank fumes adsorbed by the cannister will have nowhere to go. Before long, you'll have enough that they will overload the adsorbent and start dripping out the vent at the bottom. At best, you'll have a strong smell of gasoline on the passenger side. At worst ? ...
$70 at the dealer https://parts.lakelandtoyota.com/p/T...092505047.html
$50 (OEM) on eBay https://www.ebay.com/itm/221640891396
Just replace it.
mtrdrms
Sep 26, 2015 07:12 AM
Daneums
Jan 6, 2013 05:06 AM
vasinvictor
Sep 23, 2010 09:52 AM
yukonjack
7
Jul 19, 2006 10:00 PM
Sequoia'd
Feb 23, 2005 03:08 PM
