PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 [138] 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 93 truck gear and drivetrain questions
  2. Cig. Lighter question.
  3. motor went to crap
  4. Possible rod knock, video inside to help
  5. Alternator Advice - which one to get
  6. I want to build a sleeping platform for my 90 shortbed.
  7. nice tail lights for 1st and 2nd gen 4runners
  8. muffler poll what are you running on your yota
  9. Luck with power steering gearbox rebuild
  10. Built my hard top lift!
  11. speedometer not working.
  12. Trouble restarting when warm
  13. siezed caliper...
  14. Radiator fan blades warped=vibration in front of engine bay?
  15. Transfer Case ??
  16. Custom Exhaust questions
  17. tapping noise in 22re
  18. Flooding
  19. 93 pickup 3.0 v6 overheats at idle?
  20. Exhaust cut-outs questions
  21. Random Green wire with black stripe?
  22. My rear brakes drag after my wheel fell off
  23. trying to make running 86 22re move
  24. Suspension problem 90 4runner
  25. 93 22RE Starting Issues
  26. 1987 4runner w/ W-56 and 22re Drivetrain clunk
  27. transmission problem
  28. 3VZ no spark after fuel pump issue?
  29. 87 4runner- clutch, MC, etc problem?
  30. Reassemble 22R Head/OilPan/Timing Cover
  31. I got the wrong rear drive shaft! ARGHH
  32. oil pressure gone....where did it go??
  33. 3vze head bolt size/type
  34. rear end locked up and killed engine
  35. 86 4runner brake problem, no pedal after SAS
  36. Strange overheating problem v6 -95
  37. RPM's going up/down at constant speed?
  38. Spool Install in V6 rear.
  39. 90' Manual to Auto swap
  40. what year is this 4runner?
  41. 22re fuel filter question
  42. 4Runner speedo ?
  43. could my alternator be bad?
  44. My 1986 "Random Triangles" 4Runner (pics)
  45. 3.0 head gasket failure tests???
  46. Squeak when hubs locked in
  47. Front Rubbing Sound
  48. Pass side IFS seal- again....
  49. 86 22re low idle when cold after rebuild.
  50. bad steering bearings?
  51. Oil Disappearing over short mileage
  52. Is it my head gasket or something else?
  53. Anybody know where I can get a battery clamp?
  54. Tail Light problems
  55. "tek tek tek" sound in the morning
  56. Coolant leak location
  57. time to change tie rods
  58. transfer case leaks
  59. What would you do? Body Swap or Repair Rust
  60. Gas Smell when running need some help
  61. 22RE hard to start, then has SUPER high idle
  62. my new engine is TOAST
  63. timing issue?
  64. 1993 2re engine sensor parameters and obd1 scanner
  65. New timing chain probem 22re
  66. Interior light bulb count 92 4Runner???
  67. Steaming from motor
  68. High quality replacement fenders
  69. olemiss4runner UPDATE
  70. stopped the little odds and ends leaks, FINALLY... power steering and radiator
  71. Tap Tap Tap goes my engine
  72. Stronger Front CV Axle??
  73. power steering pulley wobbling
  74. front brake troubles????????
  75. Truck dies in drive/reverse
  76. 1994 toyota Pickup V6 4WD poor gas milage
  77. Part number help???
  78. 22re with 22ret engine harness???
  79. POWERTRAX LOCK-RIGHT Locker
  80. Turn Signal Power Draw
  81. Bypassing the OD
  82. Complete swap from auto to manual, step by step
  83. Custom Fenders
  84. paint my 91 xtracab fj voodoo blue?
  85. What size socket to remove the 3vze Head Bolts?
  86. Rear Lift Spring
  87. Flexing the '90 Toyota
  88. passenger side power window wont work
  89. Shifter stick goes around in a circle? Read what happened?!
  90. Got my 2nd locker!!!!
  91. Transfer case temps
  92. maf to amf question
  93. Leaking Antifreeze, Blowing White Smoke, can't find leak
  94. Neutral Safety/Starter Relay Problem
  95. 22re Head porting and flow
  96. Auto to manual swap
  97. o2 sensor test?
  98. Help! no power to fuel pump!
  99. Transmission issues
  100. 1994 Pickup wont start
  101. Sputter on heavy acceleration
  102. Leaf/IFS question.
  103. Hi guys, car is making a lower end noise; would appreciate a diagnosis (vid)
  104. Help, strange brake problem!
  105. Timing belt trouble...
  106. Intake Plenum/Head question
  107. 22RE starts sputtering at 2500 rpms
  108. New engine overheating with heat on?
  109. New to me 88' 4runner
  110. Valve adjustment question...
  111. Throttle Cable
  112. Engine Cut Off after a hard stop!
  113. Knock Sensor Wire Coax fix
  114. Question regarding front parking brake cable for 88 Toyota pick up
  115. 22re smoh help?!?
  116. FJ on 7th year anerviersy movie tent
  117. 4wd conversion
  118. 86 pickup w/ 22r carb trouble
  119. Trans.dipstick connection
  120. Tank issues
  121. getting really annoyed with my 22re
  122. Shackles installed!!!!
  123. LC Coil Install
  124. help identify this noise! [vid inside]
  125. 100K 88 Pickup 22r Strange Carb Trouble
  126. Quiet exhaust help
  127. 86 SR5 Ext Cab with 22RTEC
  128. Starting 22r rebuild/possible interior swaps?
  129. oil change convenience...
  130. How To Remove Front Axle
  131. please help cold start switch
  132. Rear Brake Problem 94 4runner 4x4 3vez
  133. Roof Rack Ideas
  134. 1991 3.0 litre leaking oil bad
  135. Gas smell from outside car
  136. ignition woes.
  137. turbochargin a 3vze
  138. Clutch Release Bearing hub
  139. possible problems with my A340H in 4x4 mode
  140. what is heavy duty?
  141. 86-95 IFS 4x4 GEAR INFO - READ FIRST HERE NEWBS BEFORE POSTING
  142. Turbo on my 22re
  143. 1987 22RE won't start after distributor adjustment and TPS check...help
  144. 3vze HG going??
  145. HID's making combo switch die?
  146. Bucket Seats Installed! +Pics!
  147. Wrecked my truck
  148. lost on 3vze stall
  149. Just bought my second '91 4Runner!
  150. 1st gen 4runner fuel pump help!!
  151. LSD front - steering at higher speeds
  152. 3.0 head bolt sizes?
  153. Mystery Parking Brake Cable
  154. How to deal with a rounded tranny fill bolt...
  155. lift bracket? = my rear end clunk?
  156. Setting timing '94 22RE
  157. My new (to me) first gen!!!!!!
  158. Torque on filler and drain plugs on transmission?
  159. transfer case wiring?
  160. '86 4Runner latch and sensor issues
  161. rebuilt 93 3.0 starting issues
  162. Distributors known for going bad?
  163. LCE -EFI Power Package
  164. 86 4runner seating options
  165. My head gaskets are going again!
  166. Hwy speeds with hubs locked?
  167. IFS issue
  168. Knock Sensor 22re question?
  169. 86 Body Switch...Is it possible?
  170. Looking an reputable engine builder in phoenix
  171. check out my new rims... teehee
  172. 22re Idle Check
  173. Bent frame??
  174. 86 4runner walking the road in 4 wheel drive
  175. Can I use the W56/Tcase from a '93 in my '90
  176. 3VZE cross over pipe mod?
  177. Emergency brake help
  178. HELP!! No start, no power???
  179. 3zve engine / vacuum question
  180. LCE Header turning Brown???
  181. Fixing e-brake cable
  182. 88 bed on a 91?
  183. Steering upgrade
  184. 4Lo Shifter Engagement Issue
  185. Headgaskets blown, time to determin the next step....
  186. 3vze Injector ohm difference?
  187. 3VZE Power steering pump rebuild or replace?
  188. Am I asking for too much? suspension
  189. how to remove leaf springs??
  190. Swapping leaf springs (interchangeability)...
  191. What header should I get for my 22RE?
  192. A Good Place to Get new CV Axles
  193. 3vze Engine Ground
  194. 1986 sr5 non turbo
  195. EFI fuse keeps blowing, possibly snow related?
  196. 91 4runner distributor/timing
  197. speedo cable tension
  198. 92 4Runner - ABS Actuator PS Fluid Leak
  199. Tranny Cooler Location & Maint
  200. Internal Valve Cover Gasket (Baffle)
  201. Need help converting 4x2 to 4x4 grill
  202. Help!! 94 Pickup making noises.
  203. 88 22re sputtering bad
  204. Why do I smell gas when I start up my truck?
  205. help! torsion bar break/ bent frame
  206. Heater Fan/Blower Cleaning (How?)
  207. Windshield wiper issues
  208. When should I install my Engnbldr head?
  209. 22re heater hose question
  210. Fuel Gauge question
  211. idler arm removal from steering link
  212. 4runner Window lock switch
  213. 3vze temp sensor problem.
  214. Code 11
  215. Help!!! My truck wont start warm or cold!!!
  216. Cold Start injector reading 4.3ohms
  217. Fuel injector Wires
  218. Oddball 4wd indicator light issue (not the usual)
  219. Rear U-joint: tough to grease
  220. 1990 deluxe 4x4 codes
  221. Fuel problem no start help please
  222. '89 4runner V4 auto, stalls when hot from low idle, idles fine when cold
  223. Loose A/T Shift Lever
  224. Vibrations and wheel wobble
  225. 89 3.0 V6 2wd unidentified Bracket?? Please Help
  226. help wont start
  227. 1994 toy 4x4 pickup 22re
  228. Tailgate ground wires?
  229. 3vze crank pulley wobbling and maybe going south?
  230. 10,000th head gasket question on 3VZ-E
  231. 87 4Runner 22RE emmission hose routing
  232. Anyone have any good luck with JC whitney replacement springs?
  233. mysterious oil consumption
  234. fuel gauge not working, and popping out of 1st and 3rd
  235. 94 4runner and dragging tire
  236. Just finished HG and timing, vanilla milkshake. Help!
  237. Installed a mercury electric fan today. 3.0 v6 (Kinda pic heav)
  238. Gone Overboard on '95???
  239. Popping out of 1st gear
  240. anyone know the proper name of the hood squirters
  241. Miss at constant acceleration
  242. auto trans diagnose... any ideas?
  243. 86 pickup transmission swap
  244. 94 4runner CEL code 25?
  245. 94 4runner idle and start issue
  246. 1987 4runner parking light positive wire
  247. Emissions Question
  248. 4runner rear seat *pic request* ASAP
  249. Sector Shaft seal replacement....
  250. Spring Upgrade/Swap - 87 Pickup 4X4
