siezed caliper...
Old Feb 21, 2010 | 01:44 PM
YFZsandrider's Avatar
siezed caliper...
My '94 has had squeeling brakes on the front left side for a few weeks now... finally got it apart to take a look, and the rotors look fine, no uneven wear. butthe brake pad on the inside of the passenger side is worn down, almost to the bottom of the pad material.
I have an idea that the caliper is siezed, is it worth a shot at breaking the pistons free and getting it going again... or should I just replace the caliper?
Old Feb 21, 2010 | 02:32 PM
Teuf's Avatar
Well if its off I would get a c clamp n spray oil n mess around. And or get a rebuilt one, with the core it should be cheap
Old Feb 21, 2010 | 02:38 PM
aadown1214's Avatar
I had one lock up while driving to work a while back on my 80 model. I think with core, auto zone can get you hooked up for about $40. be weary though, most rebuilt callipers have a lifetime warranty, so some of them are going to be junk. I replaced my rebuilt one once already, had bad seals in it.
Old Feb 21, 2010 | 03:03 PM
swampfox's Avatar
when in doubt replace it .it is easier to fix at home instead of on the roadside. also check to see if the caliper moves freely. i have had the inside of a brake line collapse and cause the brake not to release ,but that is rare.
Old Feb 21, 2010 | 03:08 PM
laskt9's Avatar
i would say rebuild it but its hard to find rebuild kits anymore so go get a reman caliper
Old Feb 21, 2010 | 05:57 PM
Yup, checked out the caliper, and it had one piston that would not budge! picked up a reman'd caliper at autozone for $46... Id rather have the peace of mind, than fix my old one and have issues down the road!
Thanks for the help guys.
Old Feb 21, 2010 | 06:09 PM
24Runna's Avatar
My driver side seized also! I had it on a vice with a big arse c-clamp and banged it with a BFH and it would barley budge. I paid the same price too. Oh and if you get Autozone's Duralast Gold Cmax pads (I know not very good, BUT if they glaze they replace them for free.) But I need to bleed all my brakes, the brake pedal is a bit softer than before. Theres still an air bubble somewhere in the line.
Old Feb 21, 2010 | 06:21 PM
Zinek's Avatar
DO NOT waste any thought on this issue. Replacement with a new or rebuilt is the only positive way to go.
Gutted91
Jan 3, 2020 09:48 AM
vikinghug
Jun 14, 2016 08:10 PM
94ofCanada
Aug 14, 2015 06:37 AM
drguitarum2005
Mar 15, 2007 11:34 AM
Los Gatos?
7
Mar 14, 2004 01:38 PM
