22re heater hose question
Old Feb 8, 2010 | 05:25 PM
sas'd22re's Avatar
I'm wondering which is the inlet and which is the outlet for the heater core connectors that come through the firewall. Passenger side is ??? And drivers side is ???
Thanks for the help. My computer crashed and I lost most of my tear down pics for my swap
Old Feb 8, 2010 | 05:40 PM
iamsuperbleeder's Avatar
couldn't tell you which is which specifically, but I do have this if it helps at all
Old Feb 8, 2010 | 05:45 PM
vang_22re's Avatar
Deesnt matter which one is in or outlet. It just need the hot water foe the heater but most of the time the inlet line is the one with the opening passage. If that makes Any sense. Hahahaha
Old Feb 8, 2010 | 05:47 PM
4Crawler's Avatar
Generally the heater valve in on the inlet line to the heater:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/14.html
Old Feb 8, 2010 | 06:53 PM
sas'd22re's Avatar
So the copper fitting coming out of the firewall that's on the 'drivers side' is the feed for the heater core then? Kinds tough to tell as I can't trace the hoses on the pics! Lol. Thanks for the input but please more help! I'm putting a 7mge in and need to figure out the hoses
Old Feb 9, 2010 | 12:46 PM
sas'd22re's Avatar
so is my previous post correct? the drivers side is 'to heater' and the passenger side is 'from heater' ????? thanks for the help!
Old Feb 9, 2010 | 11:20 PM
sas'd22re's Avatar
Ttt. Anyone? From the replys and pics it looks like the drivers side one is the heater feed. am I able to 'reverse' them? ie. Head-hose-valve-hose-enter passenger side-exit drivers side-hose-connect to steel return line would this work or do I HAVE to have the hot water from the back of the head enter on the drivers side? It would be easier if I could switch it but I need to know what's what first!!! Thanks again!!!!
Old Feb 9, 2010 | 11:47 PM
Truckfiend's Avatar
It doesn't matter which one goes where.
Old Feb 10, 2010 | 12:13 AM
sas'd22re's Avatar
Awesome. So as long as water goes in one end and comes out the other, everything is good? Lol. If that's the case, I'm set! Now I won't have a whole medd of hoses going from one side to the other and back. Thanks for the reply
Old Feb 10, 2010 | 12:17 AM
Truckfiend's Avatar
You got it!
Old Feb 10, 2010 | 12:41 AM
sas'd22re's Avatar
Sweet man, thanks again!
Old Feb 10, 2010 | 02:25 AM
dwest76's Avatar
inlet/outlet
On my 87 the inlet is on the driver's side and outlet is on the passenger's.
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
icentropy
Jul 14, 2015 10:23 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
