88 22re sputtering bad
Old Feb 9, 2010 | 05:39 AM
mrmorrison's Avatar
I have an 88 pickup with a 22re that is my daily driver. the other day it started sputtering real bad. I replaced the fuel filter and it didn't change a thing. I checked the diagnostic code after that and it is throwing code 51. I checked the resistance of the tps in wide open and all the way closed and everything checked out fine. I can't find my feeler guages to check in between but I will today. Any ideas?
Old Feb 9, 2010 | 09:48 AM
89rnr91rnr's Avatar
Check your injectors to see that they are firing (clicking). I discovered that my #1 injector failed causing major sputtering and hesitation. They are in the mail to be rebuilt.
Old Feb 9, 2010 | 05:13 PM
mrmorrison's Avatar
Thanks I will test them and see if they are firing. Would that make my ecu throw the code for the throttle position sensor? This is driving me nuts.
Old Feb 9, 2010 | 05:46 PM
89rnr91rnr's Avatar
Funny that you should ask, mine was throwing a code 41. Once I get the injectors back and installed I will be able to tell more.
Old Feb 9, 2010 | 05:53 PM
Jory121's Avatar
check your plug wires
Old Feb 9, 2010 | 09:59 PM
mrmorrison's Avatar
I already checked my plug wires, but not the injectors. I just dont want to buy the tps for 80 bucks if i dont have to lol.
Old Feb 9, 2010 | 10:02 PM
mrmorrison's Avatar
doh!
drivin me nuts
Old Feb 10, 2010 | 06:54 PM
mrmorrison's Avatar
With the feller guages in place between the throttle screw and stop, the ohm meter doesn't read anything.
Old Feb 10, 2010 | 07:14 PM
89rnr91rnr's Avatar
make sure your ohm meter is set at 20k.
Old Feb 11, 2010 | 10:35 AM
mrmorrison's Avatar
It was set at 20k. I think maybe the connection inside is broken or something. I got a new tps today and will let you know if it works. (fingers crossed)
Old Feb 11, 2010 | 04:58 PM
mrmorrison's Avatar
installed the new tps and it didn't work. i am not sure what to do now?
Old Feb 11, 2010 | 07:07 PM
mrmorrison's Avatar
I am thinking maybe the wiring to the tps is bad, or I got a bad tps from schucks. It doesn't even want to idle now.
Old Feb 11, 2010 | 07:51 PM
85toy's Avatar
i am having the EXACT same problem as you and i have done everything you have done so far. just tonight i determined that my wires are good because i tested with an ohm meter. i have replaced the tps with no luck and now my conclusion is i have a bad ECU. thats all i can think of im throwing the same code you are 11 which is the tps code as you know. ill be watching this thread. i plan on getting an ecu in the next couple days so if yours isnt fixed by then ill let you know how it worked for me.
Old Feb 12, 2010 | 07:45 AM
mrmorrison's Avatar
Thanks. I am not sure about it being the ecu though. I drove mine everyday before it started sputtering and I dont think the ecu would just take a like that. Also, after i replaced the tps, it stopped throwing all codes. According to my ecu, it is perfect.
Old Feb 12, 2010 | 07:51 AM
Red_Chili's Avatar
Highly doubtful it is the ECU. Follow 4Crawler's procedure for tps adjustment to the letter, you should be golden - or you will find your problem.
Old Feb 12, 2010 | 10:19 AM
85toy's Avatar
my tps is adjusted just fine, the only code im getting is code 11, which is tps, ac switch or ecu. i have replaced my tps and adjusted it i dont have ac so what else could it be?
Old Feb 12, 2010 | 03:01 PM
mrmorrison's Avatar
Yea 4 crawlers way is different than the fsm's in that it says to use a .85 mm feeler guage and my manual says to use a .47. not sure which is right, but either way I can't get my brand new tps adjusted right so I have no clue if that's it or not. It is really pissing me off and I am about to shove my truck off a cliff.
Old Feb 12, 2010 | 04:39 PM
mrmorrison's Avatar
Does anyone know what the "vsv for as" is for on the valve cover? The wires had come out of the connector and i didn't notice. Could this cause my sputtering problem?
Old Feb 13, 2010 | 12:14 PM
85toy's Avatar
bump for fix
Old Feb 13, 2010 | 01:36 PM
zachw90's Avatar
check the coil
