Is it my head gasket or something else?
Old Feb 19, 2010 | 06:26 AM
shortwing's Avatar
I have a 1987 22RE that was rebuilt about 18 mounths ago by a local shop. There is no water in the oil. Nice clean oil. 160 lbs of compression on all 4 clyenders. No bubbles in the radiator when warm and ideling with the cap off. It runs strong down the freeway at 70 mph.
But it just started smoking like a fiend, radiator water is going away and water is almost running out the exhaust. The exhaust water smells like coolant.
Steve
Old Feb 19, 2010 | 06:52 AM
snobdds's Avatar
Do a leak down test. It will tell you if it's your head gasket or not.
Old Feb 19, 2010 | 07:11 AM
shortwing's Avatar
Sorry, but what is a leak down test?
Old Feb 19, 2010 | 07:15 AM
mightymouse's Avatar
go back to the local shop and ask them to fix it.
Old Feb 19, 2010 | 07:17 AM
mastacox's Avatar
If you're burning that much coolant, it's the head gasket. Sorry.
Old Feb 19, 2010 | 07:33 AM
shortwing's Avatar
so I searched leak down test and know I know.
Old Feb 21, 2010 | 12:17 PM
Chuck Manners's Avatar
its eaither a head gasket or an intake gasket
Old Feb 21, 2010 | 12:35 PM
87toyy's Avatar
i had the same problem on a 22r carbed and a 22re. theres a small plate on the back of the head it has i around 4 bolts holding it on. it was the gasket on that was gone on both of mine. seemed like the coolent was basically pouring out the exhaust. once i fixed those gaskets no more smoke or coolent loss on either motors.
Old Feb 22, 2010 | 07:06 AM
shortwing's Avatar
I pulled the head, no obvious leaking. The gasket had a defect at the cylinder edge beside a water passage. The bolts were not all that tight, but they were not lose. The water was only going out the #4 cylinder. Some signs of combustion gases leaking between 1 & 2 and 3 & 4. The head was not even stuck to the block. Good machine work where the block was decked and the head was straight.
I think the shop used a poor quality gasket to save a little money.
Old Feb 23, 2010 | 03:49 PM
snobdds's Avatar
I always use OEM toyota head gaskets. There $47.00 and in the long run, it will save you money over that cheap junk.
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
themightykhoner
Aug 11, 2015 07:37 PM
Coreyr384
Jul 10, 2015 11:13 AM
