Truck dies in drive/reverse
Old Feb 17, 2010 | 12:32 PM
G-Force's Avatar
I have a '95 p/u w/ the 22re. Auto trans, 2 wheel drive.
my timing chain wore thru the timing cover and that where the hell began. weeks, dollars, and tears later, its sitting at my mechanics shop. I took it to the shop for an engine r&r because I dont have stuff to do it myself.
Now, it seems to run fine in park but dies in any gear but nuetral.. if you hit the gas you can get it to move forward but has very limited power. The people I took it too are pretty unfamiliar w/ auto trans and Im afraid it might have something to do with the torque coverter.
whats goin on here guys?
Old Feb 17, 2010 | 01:53 PM
AzStorm's Avatar
Sounds like your timing may be off.
I dont think its the TC.
Old Feb 18, 2010 | 11:36 AM
G-Force's Avatar
so it would run if the timing was "way" off?
ive timed it several times before. it runs smooth in park.
Old Feb 18, 2010 | 11:45 AM
G-Force's Avatar
Question
I drove it again this morning and it seems to run a lot better once its warmed up. after i drove it for 5 or 6 min it was able to idle in drive.
Old Feb 18, 2010 | 01:03 PM
INFINITY's Avatar
sounds like a vacuum leak
Old Feb 18, 2010 | 01:43 PM
fishon1213's Avatar
The timing being "way off" could definitly cause youre problems. The timing should definitley be set with a decent timing light and make sure you jumper the terminals to get base timing and go from there.
Old Feb 18, 2010 | 04:33 PM
abecedarian's Avatar
There's not really much they could've done wrong changing the engine out. Presumably they'd re-use your old flexplate and torque converter on the new engine so things should be fine that way.
If the shop simply put a timing light on and set the timing without jumpering the proper terminals in the diagnostic connector, your timing will be retarded. So I'd say like fishon1213 said- "make sure you jumper the terminals" (Te1/E1 or similar) in the diagnostic plug under the hood and set the timing correctly.
Old Feb 18, 2010 | 04:57 PM
Lumpy's Avatar
2X^^ Timing and or Vac leak.
Old Feb 20, 2010 | 08:56 AM
G-Force's Avatar
well for now the problem has resolved itself...which makes me nervous. it still has the check engine light on.
I drove over an hour last night and it seems basicly perfect.
I hope it lasts long enough for mr to save up and drop a new tranny in it.
thanks guys.
sonic concepts
Aug 16, 2025 03:13 PM
91toybeater
Dec 27, 2015 07:46 PM
puffin04
Jul 10, 2015 09:17 PM
MadMax48
Jul 3, 2015 08:26 AM
ibayne
Jun 26, 2015 06:30 AM
