1st gen 4runner fuel pump help!!
I'm in the middle of replacing my fuel pump, but I'm stuck. How do I disconnect the wires that are connected to the round cap on the fuel tank? I've got all 3 hoses disconnected, but I don't have enough slack the lift out the fuel pump without disconnecting the wires too? Any help would be MUCH appreciated. Am I missing something? The wires seem like they are permanently on the round cap...
https://www.yotatech.com/forums/f128...-years-156128/ Click on the link. Download the fsm by right clicking on one of the 85 links and left click SAVE LINK AS. When finished go to pg 214 for fuel pump there should be a plug for the wires as shown in description.
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Follow the wire back and see if there's a small stamped metal clip that the wire goes into then you form the metal around it like a twist tie to hold it out of the way.
Find that and take it out to get you some slack... But try and find the weather connector.
Any wires riveted in you don't need to remove anyway???
87blyota
Jul 1, 2015 05:26 PM
