Auto to manual swap
Old Feb 16, 2010 | 12:13 AM
SpecialScottie's Avatar
Auto to manual swap
So Im getting ready to swap my 85 over from auto to a manual transmission. I found a w56 (I believe to be a C) at the junk yard in a 91 pickup. Although it has the forward shift T-case. Would I still be able to use it as 85-88 used top shift t cases?
Old Feb 16, 2010 | 12:33 AM
malteserunner's Avatar
I have a 95 tranny/t-case in my 87. You shouldn't have any problems. I did have to trim the hole in my floorboard to clear the shifters, as they are a little farther forward than my original shifters. Good luck with your project.
Old Feb 16, 2010 | 12:35 AM
Did you need to get different shift boots or change the interior pieces?
Thanks
Old Feb 16, 2010 | 12:43 AM
My 4Runner was missing the original trim around the shifters, and the boots were in bad shape, so I built a custom cover for the tunnel, and used an ammo can for the console. It's actually still a work in progress, since I haven't added the cupholders yet.....doh. It will be done soon, however.
Old Feb 16, 2010 | 12:49 AM
Got any pictures?
So if I did this swap I would probably need the boots and trim piece from the 91 correct?
Old Feb 16, 2010 | 12:52 AM
Originally Posted by SpecialScottie
Got any pictures?
No pics yet. I will add them to my thread when I finish the cupholders next week.
I'd say using the trim and boots from the 91 would be easy enough for your swap.
Old Feb 16, 2010 | 12:54 AM
Right on. Thanks alot for your help
Old Feb 16, 2010 | 01:05 AM
Any time.
Old Feb 20, 2010 | 08:37 PM
tonyusmc27's Avatar
Let me know how your build up goes I just picked up a 89 W-56 foward shift today will be doing the same.
Old Feb 20, 2010 | 08:49 PM
What do you plan on putting it in?
Old Feb 20, 2010 | 09:50 PM
tonyusmc27's Avatar
85 4runner as well
Old Feb 20, 2010 | 09:54 PM
tonyusmc27's Avatar
I got engine and tranny from 89 with 111,000 miles. snaged crossover from manual heard crossover from auto won't work and about everything to do the swap ie clutch pedal, slave cyclinder got a pretty good deal on all of it. Cant wait to start maybe we can learn from each other this will be my first major project.
Old Feb 20, 2010 | 11:49 PM
Mine came out of a 91. Not sure how many miles. Are you talking about the crossmember? From what Ive read, the crossmember itself is the same but the rubber mount is different. Im doing dual cases at the same time
Old Feb 21, 2010 | 08:05 AM
tonyusmc27's Avatar
Yes crossmember. Well good luck let me know how the dual cases go when do you plan on starting?
Old Feb 22, 2010 | 09:46 AM
Well marlin has a sale on the dual case adapter so it might be sooner than I expcted
88sasturbotoy
Jan 30, 2026 01:57 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
deepmarsh
Aug 6, 2015 03:44 AM
KBar
Jul 13, 2015 06:01 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
