22RE starts sputtering at 2500 rpms
Old Feb 15, 2010 | 12:32 PM
cuaco-ortiz's Avatar
hi guys, need some help here.
I have an 87 4Runner with the 22RE, it started sputtering from idle to about 2000 thru 2500 (not sure, don't have a tach).
It recently was giving me a problem with a very rough idle, after replacing the fuel filter and checking the fuel pump pressure, it turned out to be a bad connection on the TPS.
But know, the issue is that it still sputters at higher rpms, it seems like its missing either more air or more fuel.
The same thing happens when I'm driving, I can not make it to run faster than it did before, it bogs down, no more power.
Does any one have any ideas?
P.S. I also replaced the ECU and it acts the same way...
Old Feb 15, 2010 | 01:19 PM
Erik Beeman's Avatar
Bench test your O2 sensor(s). they may be bad
Old Feb 16, 2010 | 06:13 AM
hi, thanks for the repply.
See, that's the funny thing, the engine is not putting out any codes, I'm not saying that the O2 sensor can't be wrong, but it just seems odd.
could it be a bad TPS?
Old Feb 16, 2010 | 08:39 AM
Blk63vette's Avatar
Clean your throttle body
Old Feb 16, 2010 | 08:47 AM
there are many things that can make a 22 sputter.
Old Feb 25, 2010 | 09:44 AM
it turned out to be the fuel pressure damper, it was starting to go out (it was leaking gas and I plugged the hole with a screw). I replaced it (expensive little f#$%@r and just as I replaced it, it ran great.
thanks for your posts...
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
HRDC0R19
Jul 5, 2015 06:43 PM
