HELP!! No start, no power???
Old Feb 10, 2010 | 03:00 PM
J's-88's Avatar
So i park in the driveway and shut off the truck, I notice I need to move over a bit so I turn the key back over and I hear a pop from my speakers and now I have no power to anything. I checked all the fuses and they seem to be good. Is there a relay that is most likely blown?? Its sitting in my driveway and im driving something else untill I have time to mess with it. I dont have many tools at home so im hoping this has happened to someone before and its a simple fix, if not Ill get it towed to the shop.
thanks in advance for any help
Old Feb 10, 2010 | 03:10 PM
Justinvd's Avatar
You checked all the fuses under the dash? and the fuses in the box right beside the battery? Have you had any other electrical problems in the last little while?
Old Feb 10, 2010 | 03:13 PM
J's-88's Avatar
ya i checked all the fuses, except behind the glove box and i think those are just for a/c and heat.
No ive been driving without any kind of troubles for atleast 5-6 months now, especially no electrical issues.
Old Feb 10, 2010 | 03:18 PM
hunter4runner's Avatar
fusible link ?
Old Feb 10, 2010 | 03:23 PM
J's-88's Avatar
Originally Posted by hunter4runner
fusible link ?
where do I find it haha
I have no power to anything man, no lights, fog lights, dash lights, turn key over and nothing.
about the only thing so far I have found that works is the dam door buzzer
Old Feb 10, 2010 | 03:25 PM
fusible links are (usually pink and green) and under the fuse box in the engine bay there the big ones
Old Feb 10, 2010 | 03:27 PM
J's-88's Avatar
if they are the 30 and 40 amp fuses in there I checked em also checked the 80 amp
any way im gettin off work now and headed home to mess with the truck
If anyone has had this prob b4 please post up.
Old Feb 10, 2010 | 05:34 PM
J's-88's Avatar
wow!
so i looked under the hood for a bit, banged some stuff around.
went into cab and tried turning it over.
I got power for a second but it acted like a dead battery so I jumped it and it started haha.
I will drive it to work tommorow and have the battery and alt. tested.
Im not any kind of tech so my question is, what would cause everything to just go out like that?? I just pulled into the drive way from a 4hr road trip and had no troubles the whole time I was away. kinda weird to me but atleast I know I can jump it for now.
btw the battery is new so I doubt its that.
thanks for the help
Old Feb 10, 2010 | 05:43 PM
corrosion on the battery terminals/corrosion in the electrical lines
bad grounds
Old Feb 10, 2010 | 05:57 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
x2 on the terminals...
Jun 1, 2021 01:51 PM
Yota.Jay
Jul 23, 2015 08:08 PM
skoti89
Jul 8, 2015 12:05 AM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
