Coolant leak location
Old Feb 18, 2010 | 05:28 PM
Rammedic's Avatar
I just installed a rebuilt 3.0 motor. Motor ran great for about 20 miles. I now have a major coolant leak into the exhaust system. There is a hole in the muffler and a large puddle of coolant under the truck. My question is, intake gasket or head gasket? I pulled everything off and removed the intake. I did not see anything that definitely says intake gasket leak. There seemed to be a little moisture in the plenum. Just not 100% sure it is the intake. What say ye? Did I mention it is a major leak? Truck ran for 30 seconds, puddle at least a foot in diameter under the muffler.
Old Feb 18, 2010 | 05:33 PM
Lumpy's Avatar
Hate to tell ya...That's typically the HG.
Old Feb 18, 2010 | 05:50 PM
boxer.fan's Avatar
Once its fixed you should clean or replace the contaminated 02 sensor, same with Cat.
Old Feb 18, 2010 | 05:56 PM
rattlewagon's Avatar
sounds to me like a HG. Good luck
Old Feb 22, 2010 | 02:41 PM
Rammedic's Avatar
Found out it was the head gasket. Being a rebuilt motor purchased from a vendor(they installed the head gasket and torqued the heads to the block). What should I expect them to do? I now have a lot of money tied up in this project that is going to have to be spent again due to an issue out of my control. Labor, fluids, gaskets, etc.
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
WellsR
12
Jul 31, 2015 03:27 PM
the1998sr5
Jul 16, 2015 06:20 AM
Avenged
Jul 9, 2015 07:55 AM
