timing issue?
Old Feb 17, 2010 | 08:46 PM
HAWAIIANSTYLE's Avatar
timing issue?
94 4runner v6... im getting a very bad misfire. no CEL. did a complete rebuild, major tune-up w/ all new parts, denso and ngk to name a few. its been running a couple months till this morning the misfiring kept me from driving to work so i got out the timing light and found that my timing was retarted. jumpered it with a paperclip and set it back to 10btdc,... still misfiring. i did notice that there wasnt any change in idle speed as i jumpered it w/ the paperclip... gonna do a compression check when i have time. in the mean time, any suggestions out there.... please help, thanks
Old Feb 17, 2010 | 09:50 PM
874runnersr5's Avatar
First sign is that there wasn't a difference in idle when you jumped the terminals. I would look into your tps first.
Old Feb 18, 2010 | 02:40 PM
MudHippy's Avatar
The TPS would throw a code if it was needing adjusted or replaced.
The FSM troubleshooting page states under Poor idling\Misfire:
1.Fuel quality
2.EGR system
3.Spark plug
4.Ignition circuit
5.Distributor
6.Engine coolant temp sensor
7.Compression
Check 1-4 before assuming it's a timing/distributor issue and then check 5-6 before assuming it's a compression issue.
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
msane99
Jul 11, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
