Neutral Safety/Starter Relay Problem
Old Feb 16, 2010 | 08:05 AM
4runhaze's Avatar
Well ive been searching around and did some of the fixes ive found but none seem to work.
When I turn my key nothing happens, lights and everything work. The headlights do not dim when I turn the key.
One thing I noticed was my neutral safety switch light usually is red and now its not. I cant seem the be 100% that it turned on before the car actually started or not. I think it should be though
I replaced the fat wire from the battery to the fuse box. The starter is brand new and all the connections are tight.
What besides the starter relay could be the problem. How do I go about finding out, I was also driving this everyday no problems until now,except i rolled the power windows down and the stop rolling up before I parked it
Old Feb 16, 2010 | 08:36 AM
BigBluePile's Avatar
Welcome to Yotatech!
Sounds like you have some issues! Hmmm, do you use your neutral safety switch ALL the time, 'cause thats kinda what it sounds like.
This also:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old Feb 16, 2010 | 08:52 AM
4runhaze's Avatar
Yeah, i have to hold the switch everytime I start it. Anyone got pictures of that jumper trick im not sure I get what to do.
Also would I have to have my ignition set to start and the neutral safety switch held since I do normally?
Or pics/step by step of checking the continuity of the starter relay. I have one of the voltage meters
Old Feb 16, 2010 | 08:55 AM
Just so we are on the same page...are you pushing the safety cancel switch on the dash or are you refering to the ACTUALLY switch that is pushed in via the clutch pedal?
Old Feb 16, 2010 | 09:34 AM
4runhaze's Avatar
yeah im talking about the dash switch needs to be held. The pedal doesnt work or something.
Old Feb 17, 2010 | 09:54 AM
4runhaze's Avatar
sorry to double post this but I have a feeling its connected to whatever made my power windows stop rolling down before I parked it. Any ideas?
Editroblem solved! It was the 40Amp fuse box thing above the relay. Listed as Am1 its the green kind. Replaced it Power Windows work and it starts up great.
EDit 2: well it worked great for a day. The fuse blew agian...would here be a problem putting a 50 amp fuse instead of a 40 amp??
Old Feb 18, 2010 | 09:08 AM
4runhaze's Avatar
Sorry to bump my edit, you can delete this
PlayAwhile
Jul 20, 2015 11:36 AM
jackiebrownia
Jul 20, 2015 09:02 AM
Poncho0206
Jul 10, 2015 06:21 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
