22re Idle Check
Old Feb 11, 2010 | 06:10 AM
podzie's Avatar
22re Idle Check
Anyone know of any cheap tools to check RPMS on a 22re? I don't have the SR5 cluster, so no tach. I have an old style dwell/tach, but I only know how to hook it to the old style coils.
I just did a 150k mile service with plugs, wires, cap, rotor, adjust valves....
When I set the timing, I jumpered the terminals and set it to 5btdc.
The truck doesn't "pull" through the gears like it should. I'm thinking I may have set the timing with the idle too low? Any thoughts?
Old Feb 11, 2010 | 08:04 AM
Rippinthewaves's Avatar
You could be off one tooth on the dist. gear. Is you dist. cranked all to one side to get 5btdc?
Old Feb 11, 2010 | 02:02 PM
podzie's Avatar
Not that big of a problem, I hope. I just need to first verify that idle is 900 rpm while I'm setting the timing and don't know of a tool that will measure my rpms.
Old Feb 14, 2010 | 08:09 AM
abecedarian's Avatar
Idle should be around 750, unless the sticker under the hood states something different.
Old Feb 14, 2010 | 05:58 PM
podzie's Avatar
Thanks for that!
Now if I could just find a tool to measure it!!
Old Feb 16, 2010 | 09:27 AM
crafthorse's Avatar
Fluke makes an ohm meter that wil also measure RPMs. I used on to set the idle on my truck.
Old Feb 16, 2010 | 10:28 AM
you may check into the auto parts store for an aftermarket tach. autozone has one for $30 and a tune-up multimeter for 55
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sandman
Jul 14, 2015 12:36 PM
ryerye13
Jul 14, 2015 08:27 AM
