- Re-flashing ecu
- Any Toyota techs out there????
- Coolant on floorboard inside truck
- battery
- 5 speed swap
- clutch
- Rebuilding a 3.0
- Brand freaking new
- awesome 2nd gen rear bumper
- Annoying clunk type noise on take off?
- used parts buying?
- Crankshaft bolt specs.
- ebay h4 conversion kit installed
- size of crossmember bolts
- ivan fenders
- toyota front axle
- is a 5 speed from a 22 re same as v6?
- New 86' Pickup
- Interchange Fuel Tanks
- Power window motors?
- 22RE TPS issue. Please Help!!!
- Idling Problem
- coolant leak sources
- egr valve cleaning
- Knock Senser Connecter
- What do you think of my nice rack
- Rear brakes grabbing bad
- Anyone had any experience with Motor Time?
- need help ID'ing some parts
- 22re Short block pricing differences from Toyota
- Pull the bed or drop the tank?
- Airlift 1000 installed
- Maaco Paint Jobs???
- Rig Maintenance
- 3.0 Air Intake
- lockers
- T-case, tranny impact strength
- Rough Country new 4-5"4Runner lift kit best part, $799
- Toyo is making a 33x10.50!
- Loose shifter?! No Reverse?!
- Tire chain discussion
- 22re cam timing
- Drivetrain issue - need help diagnosing...
- easy to steal?
- Was thinkin about customizing my smittybilt front bumper
- Pops out of gear
- well I finally did it!
- 2nd gen Front End Options ?????
- Tire Recommendations
- Ford guys thumbs down
- Rear Driveshaft Interchange
- Parts wanted..
- my mistake
- Got some snow/mud tires
- Body swap?
- SusPect Smoke
- Another 22r surging issue
- Freshly Rebuilt 22r No start
- 1991 22RE won't run right.
- 22re no power above 3500RPMs
- We've got a dead soldier
- Why haven't my rings seated yet???
- so what can you guys say...
- IFS to SAS..SAS High maintenance issues??
- 3.0 Head Gasket
- steering knuckle swap
- EFI Fuse.....again...
- 1990 3vze tach troubles
- Hose kit?
- ignition lock cylinder
- 22re valve guides
- Bracket lift??
- where to put seafoam
- 1994 4Runner Brake Problem
- Head Gasket Removal
- 91 yota 2wd Automatic Lift????
- Lazyboy
- 93 slow rpm varies
- halfway through the headgasket
- front difff
- 94 runner w/acceleration difficulty
- 3vze ecu compatability
- look what norbert got
- Cat
- GlassPack!!
- radio plug cut.. which colour is +12v
- anyone in Canada want a project truck?
- How to get cam sprocket on!!!??!!! 22re
- Speed sensor????
- Necessary to replace head bolts?
- Rims?
- Rims?
- First drive with the Supra MAF
- Squeaky Truck
- PCV system/ front breather question
- 93 4Runner Lowering Rear window
- new suspension
- Gah what do i do now?
- Who's got the highest odometer reading?
- Exhaust and Cat, lets settle this
- OMG IFS Flex!!!
- Wow...That was a nice surprise!
- Mean Green Alt on 94 4runner
- New to the forums...and some good wheelin pics!
- FYI Repair and Service Manuals
- my friend in his 1994 toyota ext p/u stuck
- stalling problem...
- Bent frame?
- craigslist 4runner, dammmm
- Air Flow meter????
- Did a bit of wheelin today
- Attarco!! Please Read!!
- want to know which car to keep
- Yet Another Overdrive Question
- Rear Main Seal question?
- Seat belt interchangeability?
- That time of year again (Storage time)
- New game for this forum
- Header question for 3.0
- Big Questions about Ball Joint Spacers.
- Speedo Gear (Transfer end)
- Supra MAF, need measurements
- 87 4cyl pickup- is it manual locking hubs??
- need help with crank question!!!!!
- fuel injector problem
- powerdoor lock
- Need help with clutch pedal bracket replacement
- Need Opinions and Lift
- 3.0 spittin and sputtering
- really noisy rear window
- Score!! Roll bar with pad and Supra MAF!
- How to indentify the type of transmission ?
- Crankshaft Pulley
- Poor spark from coil. Diagnosing?
- 400 bucks, right?
- Intake manifold bolt snapped!!
- 31x10.50r15 on stock 22re, stock 4.10's?
- Blown fuse issue
- 1992 land cruiser 4 sell or trade $3000obo
- I'm very down...
- Bad TPS?
- Got stuck today for like 4hrs
- turbo...
- Driving a few miles with no rear shocks!
- New Header - Header Bolts ?.
- 86 22RE EGR elimination "How To" with PICS!
- 86' 4runner Transmission ?????
- New member
- 22re RPM question
- Broken bolt.
- need a lift for a 1992 4 runner.
- Rough idle/miss out of the blue...22re
- 4runner lake jump
- To drive or not to drive tonight
- Missfiring
- cone filter shield?
- '91 4rnr v6 No title $500. Worth it?
- Downey Torsion Bars
- bj spacer question
- 3.0 how meny miles?
- ? Cargo Racks In The Winter
- 1st gen 4runner roof leak ?
- ?? Head Shim/Deck the block??
- My A/C is COLD...
- engine problems help!!!
- 87 4runner - tie rod rubbing frame - HELP!!
- 3.slow may not be that bad!
- dual OEM front tow hooks
- vacuum lines
- Need wheel bearing help..
- gear ratio for '89 toyota pickup???
- what parts
- 3.0 ticks underneath truck
- 22re Balancer Bolt Thread Pitch
- axle fit
- Would it fit?
- 89 4Runner no vent window need rubber seal around window
- Talk about ECM's
- how hard would it be...
- Can't figure it... UCA's ???
- caughing up foam dust... but i think it was worth it.
- Wet air filter stopped running
- idle problem
- Data link connector Location ????? Help
- first post. check out my 4runner
- tranny/clutch noise
- Best Weber carb for '87 pickup
- DRL Marker Lights.
- 4runner roll bar in a pickup?
- 22re fuel milage question
- 89 - 95 4runner Drivers door fit a 91 Pickup?
- AutoChevy is giving resistance
- Weird Speedo Problem - Pegged.
- trans
- 4runner altimeter
- looking for 3vze engine
- My New 94!!
- Anyone know the true odometer reading?
- LC Engineering Exhaust & LC balanced Injector install & review
- '91 pickup af issue
- Bearings- so it isnt so....
- 35s on IFS
- thinking about shocks and a lift
- 1994 pickup grille guards???
- Will This Front Diff Work On My Truck?
- 3vze loosing coolant
- Lockers???
- cooling fan freak
- stereo install but not all speakers work ???
- Another Aussie Locker Review
- Changed Speed Sensor, now what?
- Stock height of an 86 4runner?
- 3VZE Engine Question
- Black third gen runner lifted in south nj?
- '90 4Runner 4wheel drive gasket needs part/info!
- Swapping entire driveline + 7mgte, anyone?
- 22RE Replacement, wiring questions
- body lift
- steering stabalizer kits?
- constantly overheating a/t
- My New Rig
- What gears do I have and what do I need to run 33's
- bushings
- Add a Leaf
- O2 sensor- Denso Universal vs. Denso OEM
- How 'bout some results?
- Flow from the air vent question
- What do you call the "climate zone selector?"
- Almost crashed at 60mph!!!
- 1990 4runner v6 distributor problem? Cranks but wont start.
- 1994 toyota pickup mods
- Funky Clutch..help!
- ??? Rod Cap Removal ??
- Come-along recovery w/ pics!
- 4wd top speed
- Power Attenna problems
- installing a camshaft
- Anyone get a K&N (or similiar) on their 86 EFI 4runner?
- Power Antenna
- What gears, in what???
- Cv cant get it back in
- Worldwide parts are garbage?
- Fuel Injector replacement & T.B. screw question...
- Wanted - 1995 4runner
- Ideas for crappy mpg
- starter on a 91 4wd pickup
- cutting in half
- overheating.. i think
- A Newbie and my 91 4Runner
