Attarco!! Please Read!!
Old Nov 15, 2008 | 04:07 PM
camo31_10.50's Avatar
i thought our attarco head was doing fine on our '86 4x4 xtra cab pickup...which it is...but we guess they sent us a cam for a 22RE...because the lobes on the cam are worn about 1/4 in..(theres a lip on the very outside edge of the cam to prove this..pics WILL COME)..so we have to pull the head bolts..which means NEW GASKET...which means $$$$$$$$$...so..this time...im thinking of MAYBE building this head...OS valves...cam from LCE..by the way...which would be the best cam for the MOST improvement over stock in terms of HP/TQ/and MPG's..thanks for any info..and please..if you have an attarco head..please remove your valve cover IMEDIATELY!..and check your cam for wear...
Old Nov 15, 2008 | 06:28 PM
Matt16's Avatar
HAving a 22RE cam in a 22R engine wouldn't make it wear fast. If they are different, then it would just make it run badly most likely.
Did you break in the cam properly?
Old Nov 15, 2008 | 07:04 PM
DeathCougar's Avatar
the 22R and 22RE camshafts are the exact same thing. The wear sounds like it has nothing to do with Attarco heads, but WAY over tight valves.
Old Nov 15, 2008 | 08:02 PM
nothing was over tightened...but for some reason..we had to adjust the lifters almost ALL the way out..if we had adjusted them out anymore..then they would have stripped off thereselves..never said it had to do anything with the head...but with the cam that came with it..
Old Nov 15, 2008 | 08:03 PM
what is the proper break in procedure for the cam?..because our "mechanic" just put everything together..and said..there ya go..go see how it drives...he did something to the timing to break something in..but i cant remember what..
Old Nov 15, 2008 | 08:25 PM
YoterUp's Avatar
Cool
Well 1st thing you need to do with new cams is start the truck and let it SIT and idle for 15 minutes without moving the RPS up or down, if im not mistaken it says to let idle at 1500RPMs i could be off on that number tho. then my machine shop guy told me to put 50 miles on them with original oil at no more then 2500RPMs then change oil to a regular 30wt. for the next 500miles,All this time driving it at normal operating conditions without a load. after that 500 miles you need to change oil again after that you can switch to synthetic. (this is for a full rebuild) thats what i was told if its differant then that then i missed the memo!
P.S see i posted on your thread and did mention anything about shooting at you!
Old Nov 15, 2008 | 08:39 PM
well we let it sit and idle for probably 20 mins or so..while we set the timing..and checked various other things..as for the rest of it...no..lol...
sorry about earlier Yoterup...i was in a pissed off mood about my truck..then i seen the deer u killed with your 22..and in oklahoma..its illegal..and i thought u were from around these parts..lol
Old Nov 16, 2008 | 07:09 PM
Pistonman's Avatar
Do not idle to break in a cam.
Old Nov 16, 2008 | 07:14 PM
TOYOTA 1's Avatar
^x2...
Old Nov 16, 2008 | 07:27 PM
YoterUp's Avatar
http://www.348-409.com/fireup.html
Just to say someone else says the same thing YOU DO LET IT IDLE!!! and RPMS on that idle depend on the motor your working on!
Old Nov 16, 2008 | 07:41 PM
TOYOTA 1's Avatar
it says no where in there to let it idle during break in..
the links info is correct though, keep the motor reved up to or around 2,000 rpm's for 20min. the point of that is to get good oil flow to the top end during break in!
Old Nov 17, 2008 | 07:27 PM
well...even though i kinda bashed attarco...i guess their Customer Service is fantastic...they are giving us a BRAND NEW HEAD from Attarco..THE WHOLE THING...cam, valves, head, complete gasket set...EVERYTHING..for FREE..no cost AT ALL..free shipping.everything...idk what went wrong last time..but hopefully is was not something to do with the cam..and it was hopefully the guy puttin it together...thanks for the link...i'll do more research on how to properly break in a cam/brand new head..thanks!
Old Nov 17, 2008 | 07:35 PM
TOYOTA 1's Avatar
sweet deal..
Blamalam
Mar 12, 2022 07:34 AM
crammit442
7
Nov 29, 2017 12:30 PM
trailgoat
Aug 13, 2015 05:54 PM
Yota.Jay
Jul 23, 2015 08:08 PM
Coreyr384
Jul 10, 2015 11:13 AM
