tranny/clutch noise
Old Nov 13, 2008 | 01:53 PM
xenogear_id's Avatar
Question tranny/clutch noise
sup people. On my 86 pickup when I put it in 3rd 4th and 5th there's a clunk noise when I release the clutch. I try shifting at defferent rpm's and the noise is still there. Other then that the truck drives fine. Gos in gear perfict, shifts easy. When I shift in 5th its alttile louder then 3rd and 4th. I push the clutch back in and release it there's no cluck noise. its only when I shift from one gear to another. And there's a old barring out/grindish noise then I'm in 5th at a low rpm but as I drive faster in gear that noise gos away. Can some give me some ideas on what the problem is or if this is normal ? Its been in the mud. I bought the truck 2 weeks ago and it looks like no one kept up with it. I had brake problems I'm still working on. Thanks 4 any info.
Old Nov 13, 2008 | 02:07 PM
I haven't checked the fluid idk how. I see a drain plug and anther plug on the side of the tranny box. I dont know if this has anything to do with this prob??
Old Nov 13, 2008 | 02:32 PM
laxyoat99's Avatar
check the fluid yes thats a place to start
Old Nov 13, 2008 | 03:33 PM
so how much fluid is suppose to be in there and how do I check to see if its full?
Old Nov 13, 2008 | 03:38 PM
kev's Avatar
kev
u-joints in driveshaft?
Old Nov 14, 2008 | 02:06 PM
Well I took my truck to the shop. It turned out being my tranny bearrings 7-800 bucks. So you hear a cluck after releaseing the cluch? That's your problem.. Be ready for a bearring kit.
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
