Lifts.....Tires
Old Nov 10, 2008 | 12:05 PM
Nothingbutyoda93's Avatar
Lifts.....Tires
Im looking for a cheap but Quality lift for my 93 Pickup.
Also a place to get it put on. any good places around me.
An i want new off road tires but im not looking to spend 1000 bucks on um
what is the best bang for the buck
Old Nov 10, 2008 | 01:02 PM
Alex 400's Avatar
do a search!!!! there are so many threads on cheap lifts. You can fit 33x10.50 tires with no lift.
Old Nov 10, 2008 | 01:07 PM
904_runner's Avatar
X2.
Search for it, somebody just did a whole thread about all the possible lifts available.
theres ball joint spacers.
body lifts.
bracket lifts
torsion bar lift
Sas
etc. Its all up to you.
Old Nov 10, 2008 | 01:10 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Look at the sticky's at the top of the page
Old Nov 10, 2008 | 01:14 PM
what is better Body lifts or an actual supension lift
Old Nov 10, 2008 | 01:18 PM
904_runner's Avatar
Once again, all personal opinion.
Some say they don't like body lifts for what ever reason they have.
others like body lifts because it allows to run bigger tires, you can get closer to a flat belly, and you don't weaken the ifs by changing the angles on the steering components.
Old Nov 10, 2008 | 01:52 PM
Junkers88's Avatar
Your best bet right now is to try the search function and be prepared for a lot of reading. But in the mean time.
For inexpensive tires go to treadwright.com.
For a mild lift that you can do in the driveway I recommend ball joint spacers and either an add-a-leaf (if you have leaves), adding a coil spring helper (again if you have leaves) or coil buckets (if your truck has coils).
Oh and if you're planning on going with bigger tires start thinking about gears to match..... and perhaps a locker or two........
Welcome to the addiction.
Old Nov 10, 2008 | 05:14 PM
tc's Avatar
tc
Least expensive way?
Install 33x10.50 on your stock rims, bolt em on and drive away. This method also eliminates all the downsides of a lift - higher center of gravity, increased steering component wear, etc.
Old Nov 11, 2008 | 05:14 PM
Exclamation
Thanks dude that was what i was looking for. I just cant afford a lift right now an i have a/t tires but i want something more aggressive. If i do go in this direction, what gears would i have to think about. i mean thats a pretty big job isint it
Old Nov 11, 2008 | 08:28 PM
Matt16's Avatar
Your COG goes up the most with a tire lift. Your lifting everything including the axles up 1" if you from 31" to 33" tires. Mind you, it that lifting this way is the most effective in terms of performance gains.
Old Nov 11, 2008 | 08:38 PM
abecedarian's Avatar
how can I put 33's under my 88 4runner without having to beat on the truck to make the tires not hit the fender when I have the steering wheel turned all the way to the side and I hit a bump?
the truck came with 28" tires stock
Old Nov 11, 2008 | 08:43 PM
904_runner's Avatar
^ well abe, its real simple...
I figured you have been round here enough to know this already. but...
Just let them rub! After a while, your fenders will be formed a bit more, and will no longer interfere. Best part is, its free!!!!!!!!!!
Old Nov 11, 2008 | 08:44 PM
91Toyota's Avatar
33's won't fit on the truck...my brothers truck with 31"s rub so definitely NOT 33's.
Old Nov 11, 2008 | 08:51 PM
904_runner's Avatar
^ What
31x what???
and 2wd, 4wd?
Old Nov 11, 2008 | 08:55 PM
Alex 400's Avatar
dude. it is a well known fact that says 33's can fit with no lift. does your brothers truck have different rims because that will make them rub. 33x10.50 (skinny) will fit on stock rims with only slight massaging of the fender wells.
Old Nov 11, 2008 | 08:56 PM
scuba's Avatar
Originally Posted by 904_runner
^ What
31x what???
and 2wd, 4wd?
2wd...and 31 13.5
Old Nov 11, 2008 | 08:57 PM
algranger's Avatar
What? is it 2wd?? i ran 33x12.5's on my old truck with stock susp and no rub.. it was an 86 and ive seen it done on 3rd gens
as for lift ideers:
its kind of like you can get quality or low cost.
imo cheapes lift you could do without sacraficing the strength of yer rig would be this:
2" bj spacers
an inch or less of tbar if you want it
rear 3" aal
shackles if you want em
for tires i would recomend bfg muds or a/t's they are a very nice tire and easy on the wallet
Old Nov 11, 2008 | 09:04 PM
904_runner's Avatar
Originally Posted by scuba
2wd...and 31 13.5
and 2" backspacing.
Old Nov 11, 2008 | 09:08 PM
STEvil's Avatar
If you cant make 33's rub you arent trying hard enough
235/75/15's on my truck, they nearly touch on the rear. Front will take 33's no problem though because it is really hard to stuff the torsion bar setup into the wheel well without lifting a tire.
Old Nov 11, 2008 | 10:22 PM
Alex 400's Avatar
talk to TC and tell him that he doesn't push is stock truck with 33's hard enough. The key is the 10.50 width.
