Lifts.....Tires
Im looking for a cheap but Quality lift for my 93 Pickup.
Also a place to get it put on. any good places around me. An i want new off road tires but im not looking to spend 1000 bucks on um what is the best bang for the buck |
do a search!!!! there are so many threads on cheap lifts. You can fit 33x10.50 tires with no lift.
X2.
Search for it, somebody just did a whole thread about all the possible lifts available. theres ball joint spacers. body lifts. bracket lifts torsion bar lift Sas etc. Its all up to you. |
Look at the sticky's at the top of the page
what is better Body lifts or an actual supension lift
Once again, all personal opinion.
Some say they don't like body lifts for what ever reason they have. others like body lifts because it allows to run bigger tires, you can get closer to a flat belly, and you don't weaken the ifs by changing the angles on the steering components. |
Your best bet right now is to try the search function and be prepared for a lot of reading. But in the mean time.
For inexpensive tires go to treadwright.com. For a mild lift that you can do in the driveway I recommend ball joint spacers and either an add-a-leaf (if you have leaves), adding a coil spring helper (again if you have leaves) or coil buckets (if your truck has coils). Oh and if you're planning on going with bigger tires start thinking about gears to match..... and perhaps a locker or two........ Welcome to the addiction. :spank: |
Least expensive way?
Install 33x10.50 on your stock rims, bolt em on and drive away. This method also eliminates all the downsides of a lift - higher center of gravity, increased steering component wear, etc. |
Originally Posted by Junkers88
(Post 50967406)
For inexpensive tires go to treadwright.com. For a mild lift that you can do in the driveway I recommend ball joint spacers and either an add-a-leaf (if you have leaves), adding a coil spring helper (again if you have leaves) or coil buckets (if your truck has coils). Oh and if you're planning on going with bigger tires start thinking about gears to match..... and perhaps a locker or two........ Welcome to the addiction. :spank: Thanks dude that was what i was looking for. I just cant afford a lift right now an i have a/t tires but i want something more aggressive. If i do go in this direction, what gears would i have to think about. i mean thats a pretty big job isint it |
Originally Posted by tc
(Post 50967612)
how can I put 33's under my 88 4runner without having to beat on the truck to make the tires not hit the fender when I have the steering wheel turned all the way to the side and I hit a bump?
the truck came with 28" tires stock :D |
^ well abe, its real simple...
I figured you have been round here enough to know this already. but... Just let them rub! After a while, your fenders will be formed a bit more, and will no longer interfere. Best part is, its free!!!!!!!!!! :hillbill: :jk: |
33's won't fit on the truck...my brothers truck with 31"s rub so definitely NOT 33's.
^ What :think:
31x what??? and 2wd, 4wd? :think: |
Originally Posted by 91Toyota
(Post 50969095)
Originally Posted by 904_runner
(Post 50969107)
^ What :think:
31x what??? and 2wd, 4wd? :think: 2wd...and 31 13.5 |
(Post 50969095)
as for lift ideers: its kind of like you can get quality or low cost. imo cheapes lift you could do without sacraficing the strength of yer rig would be this: 2" bj spacers an inch or less of tbar if you want it rear 3" aal shackles if you want em for tires i would recomend bfg muds or a/t's they are a very nice tire and easy on the wallet |
Originally Posted by scuba
(Post 50969118)
2wd...and 31 13.5
:hillbill: |
If you cant make 33's rub you arent trying hard enough ;)
235/75/15's on my truck, they nearly touch on the rear. Front will take 33's no problem though because it is really hard to stuff the torsion bar setup into the wheel well without lifting a tire. |
Originally Posted by STEvil
(Post 50969143)
