DRL Marker Lights.
Old Nov 13, 2008 | 11:04 AM
Kinked's Avatar
DRL Marker Lights.
Hi,
I am wanting to disable the DRL's on my 91 but still want to have the marker lights on. I've searched the DRL threads to no avail. is there anyway to do this that anyone has tried. i just don't like the idea of no lights at all but want to put some better head lights in without them running all the time.
thanks in advance
Old Nov 13, 2008 | 01:35 PM
leebee's Avatar
there has been quite a few posts re: drl disable. i cannot recall who posted up specifics for model years but, once you find out how to disable, put your new hl's in and just run the markers via the stalk switch.
apparently, my 93 module is under the ashtry/shift console area. somewhere.
lee
Old Nov 13, 2008 | 04:27 PM
Kinked's Avatar
i know how to disable them, i would just like the headlights disabled tho.. and not have to worry about turning anything on
Old Nov 13, 2008 | 04:34 PM
abecedarian's Avatar
if yer into circuit design, a relay that is off when the voltage is below (X) and is on when voltage is above (X) is what you should probably do.
Old Nov 13, 2008 | 05:14 PM
space-junk's Avatar
+1... if not, just get used to turning the stalk...
Old Nov 18, 2008 | 08:57 AM
Kinked's Avatar
i'll give the circut thing a try, see what happens
Old Nov 18, 2008 | 09:48 AM
Belize Off Road Team's Avatar
Ok, in front of the shifter is a cover, take off the cover and you will see a DRL module, take it out and look at all the wires. Look for a Black wire with Orange stripe. cut that and you'll be DRL free. 92-95 are different to 90-91.
Old Nov 18, 2008 | 10:27 PM
shancerlelby's Avatar
cut the black orange and just twist the stalk to turn on your park lights. i like poco
Old Nov 19, 2008 | 11:35 AM
aviator's Avatar
So far as it goes the factory DRL circuit on the Canadian 4runners/trucks only turns on the headlights, the running lights are dark until you turn them on with the switch. So what you are actually wanting to do is change the whole circuit. This might be possible but you'd have to go through the circuit diagrams and do a fair bit of rewiring. Here are some links to the online FSM pages you need...
http://www.ncttora.com/fsm/1990-1995...es/wiring.html
see page 1 in above link
It looks like you'll need take the W-G wire (shown beside the battery) and disconnect it from the headlight harness. and connect it to...
(see page 1 in link below)
the G wire at position 11 of the integration relay shown at the top of the page.
THIS IS ONLY MEANT AS A PLACE TO START. I HAVE NOT DONE THIS MOD MYSELF. IF YOU TRY IT I RECOMMEND YOU CHECK POLARITY OF ALL WIRES BEFORE YOU CONNECT THEM, TO PREVENT SHORT CIRCUITS AND USE AN INLINE FUSE IN YOUR JUMPER CONNECTION... JUST IN CASE.
Hope this helped.
Old Nov 19, 2008 | 11:45 AM
Kinked's Avatar
I'll give it a try... hopefully i still can work with electronics
Ditch Doc
Oct 27, 2015 03:20 PM
Scotttekoch
Aug 31, 2015 06:09 AM
flg8r22
Aug 30, 2015 10:59 AM
mreagen
Aug 18, 2015 06:37 AM
razorman8669
Jul 12, 2015 12:13 PM
