need help ID'ing some parts
Old Nov 18, 2008 | 09:17 AM
tyes's Avatar
Just put in a new 3v, my old one blew out. Im having issue pluging everything back. I got about 90% of the job done just little touch ups..
On this picture cant really identify what hoses plug in to what?
I have 2 hose about a 14 inches in length that runs to this power steering unit, also a little confuse where it goes?? I think one goes to a tube by the firewall. I might be wrong..
These sensor are located by the Water ByPass Outlet, located behind the manifold between both LH & RH heads, i dont really know where this one in particular belongs to. As well as the outlet it self, does not seem like it has any other tubes to go to.
What the HELL is this plug? I've been searching for 2 days now and no progress on this sucker..
Old Nov 18, 2008 | 09:27 AM
jason191918's Avatar
That second pic is a vacuum line that goes to the intake.
Here is your vacuum pics.
http://s262.photobucket.com/albums/i...alve%20Covers/
pw=yotatech
Old Nov 18, 2008 | 10:06 AM
scuba's Avatar
The last picture looks like your diagnostics box...Is it close in the harness to your fuse box ?
EDIT: JASON191918 !@!@!#$111 FTW !!
Old Nov 18, 2008 | 10:25 AM
tyes's Avatar
There is no diagnostic box only a fuse box that i can find.. my fuse box has an opening inside almost the same size but not quite to fit.... what does a diagnostic box look like??
Edit: Found and done with. plugs to nothing.... only for testing...
Old Nov 18, 2008 | 10:26 AM
tyes's Avatar
pw=yotatech
very helpful, thanks, got 1 plug in from you pictures. many more to go. thanks a million,
Old Nov 18, 2008 | 02:19 PM
Old Nov 18, 2008 | 02:56 PM
just a 22re's Avatar
wow looks like a nightmare man sorry to see that but i do hope the best for you man if your having trouble my buddy just got a 89 runner with a 3slow and i can just look at it and snap a few pictures or something on them if you need me to
Old Nov 18, 2008 | 04:08 PM
tyes's Avatar
man if you can do that, it will be greatly appreciated...i cant seem to find any info or diagram on the net on this stuff... please anything...
Old Nov 18, 2008 | 04:46 PM
What else do you need to know?
http://www.ncttora.com/fsm/1993/engine.html
Old Nov 19, 2008 | 08:52 AM
tyes's Avatar
These are even more detail then the ones found in the chilton manual...where do you get all these sites??
Old Nov 19, 2008 | 08:59 AM
TNRabbit's Avatar
That is from the '93 FSM which is in a sticky at the top of this forum....
Old Nov 19, 2008 | 10:21 AM
tyes's Avatar
Here is the revision picture of the third picture: Im need to know which plug it goes to on the arrow to the (LEFT) and arrow to the (RIGHT), which water hose it connects to.. There is no manaul I can find this info in.. Please do help...
Old Nov 19, 2008 | 02:19 PM
tyes's Avatar
come on man, still stuck on the manifold and that water by pass plug.. anyone??
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
akaphilly
Jul 9, 2015 02:34 PM
