22re valve guides
Old Nov 17, 2008 | 07:49 AM
DupermanDave's Avatar
22re valve guides
Can the valve guides in the 22re be removed and replaced, or are they built-in to the head?
When I did the head job a while back, I never thought to take notice of the valve guides. (it was my first head job I did on my own)
Old Nov 17, 2008 | 08:04 AM
Yoda's Avatar
replaceable
Old Nov 17, 2008 | 08:44 PM
I'm going to replace them with the head still on. It has to be done soon, but i dont have time to do the entire head/gasket again.
any tips before i order all the parts? what should i be buying in advance?
Old Nov 17, 2008 | 08:48 PM
91Toyota's Avatar
Truck still burning oil?
Old Nov 17, 2008 | 09:27 PM
anotherjeff's Avatar
"...I'm going to replace them with the head still on..."
Ummmm..... Methinks that you are referring to the valve guide seals!
Your gasket set should have included the seals.
They say, that the seals can be replaced without removing the head. The trick is using compressed air (via the spark plug holes) to hold the valves closed.
Old Nov 18, 2008 | 04:04 AM
Yoda's Avatar
Can't do either with the head on. To get the valve springs off, you need to pull the rockers (that means the head bolts are out) Any compressed air in the cylinder will lift off the head.
The seals are easy, the guides have to be pressed out/in at a machine shop.
Old Nov 18, 2008 | 05:25 AM
eatmorechicken's Avatar
You might be able to do it without removing the rockers if you back the adjuster screw all the way out. You might be able to work the spring around it. Don't know for sure though, I havn't tried it. The thought just popped in my head.
Old Nov 18, 2008 | 08:32 AM
Yup. And I'm sure it's something with the valves.
Ok, I guess I'll just wait a year and do another head job on it. I wanted to do it soon because I need new o2 sensors, and I dont want the smoke damaging the new sensors.
I already replaced the valve guide seals. I was going to replace valve guides next, since the valves themselves are brand new.
Old Nov 18, 2008 | 12:34 PM
91Toyota's Avatar
You could buy a new head...like a performance head or something. Might as well if your tearing into your truck again.
Old Nov 18, 2008 | 12:38 PM
Volcom's Avatar
I had to reseat one valve guide when I did my rebuild. Put it in the shop oven at 200 degrees F and then pounded back down. I checked the valve guide clearances and all of them were within spec (head at 140K on it).
I imagine you could pound all the guides out after heating the head and then replace them with new guides.
Old Nov 18, 2008 | 01:19 PM
That's what I've been considering. Engnbldr has some good prices, but I've seen the same heads on ebay for cheaper. Maybe engnbldr has a warranty.
Oil levels have been staying about the same now. it's still burning, but slowly. i just checked the coolant overflow and it seems low. i remember filling it almost all the way. I know I have coolant seeping from the water bypass gasket, but I haven't made a new RV gasket for that yet. That's going to be done next sunday for winter preparation.
I'm still guessing it's valve guides. i dont have access to any shop materials, or shop ovens, so pounding and heating up doesnt sound like an option. and since i was planning on getting a performance head anyway, i guess i'll just hold off on any work i was planning on doing.
Old Nov 18, 2008 | 01:46 PM
91Toyota's Avatar
Yeah...sounds like holding off is about your best bet right now.
I'm still burning oil too...not sure if its because the rings haven't seated or what...but I was told to buy a vacuum gauge and hook it up and see whats going on.
Good luck!
Old Nov 18, 2008 | 02:12 PM
I just wish there was a local place I could swap my head at. I could get it done in one weekend and one paycheck. Just take in my head, leave with a new one and install it that evening.
I know there's toyota specialists in the denver area, but does anyone know if they have street RV heads? I'll call around.
montanatruck
Feb 26, 2017 07:07 AM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
1996Taco
Jul 20, 2015 12:02 AM
razorman8669
Jul 12, 2015 12:13 PM
