Squeaky Truck
Old Nov 16, 2008 | 09:45 AM
MidtownYota's Avatar
Squeaky Truck
My truck has a suspension squeak on the passengers side (I know because it makes the noise when i push on that part of the truck). I am not sure what it could be as i am not really a mechanic. I also have a rasp that comes from the same area when i first start driving that (the rasp) increases in frequency with the speed i am driving. (Higher speed, More noise) This is my first toyota so i dont know the basics ( if this is one of them) and would like some help on it, or if a thread has already been posted on it, i could not find one that was related.
Old Nov 16, 2008 | 10:35 AM
misterzee's Avatar
Age seems to make our old Yotas creak, just like it makes Grandpa creak. You can spray silicone or PB Blaster in between the springs, into the bushings, but you better not try that on Grandpa.
Old Nov 16, 2008 | 10:58 AM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
My old '91 longbed always had suspension sqeaks. Heard it the 1st day I drove it home from the dealer in '91, pulling in the driveway. The sqeaks, and creaks are very normal. Now as for the "rasp" sound, I'm sorry, I can't help you with that....
Old Nov 16, 2008 | 01:09 PM
Jay351's Avatar
Things to check:
Front:
Control arm bushings
Sway bar bushings and end links
Rear:
Leaf spring and shackle bushings
Old Nov 21, 2008 | 04:15 PM
thanks for the info, i check those things
Old Nov 21, 2008 | 06:00 PM
abecedarian's Avatar
squeeks- control arm bushings, sway bar bushings, dry ball joint(s) or tie rod ends.
"rasp" (scraping like sound maybe?)- wheel bearings, cv-joint, brake rotor / pads.
duckhead
170
Nov 13, 2017 06:07 AM
MadMax48
Jul 3, 2015 08:26 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
Corey
23
Jun 13, 2002 03:59 AM
