Air Flow meter????
Old Nov 15, 2008 | 04:51 PM
Skinamer's Avatar
Air Flow meter????
Hey guys, my air flow meter is not checking out properly, per FSM specs. I am looking into buying a new one, but there are several different brands and price ranges. Is there any brands I should avoid?
Old Nov 15, 2008 | 04:56 PM
bigt's Avatar
i opened mine up and the wi res are so thin like foil..2 of them were off from someone opening it before..
soldered them back and bingo bango it worked!...
i would suggest going to a junkyard they are pricey from dealership!! but i would get oem
Old Nov 16, 2008 | 05:54 AM
Skinamer's Avatar
What about the Throtle Position Sensor? Do you recommend using OEM for that also??
Old Nov 16, 2008 | 06:58 AM
mt_goat's Avatar
Yes, any sensor or electrical part.
Old Nov 16, 2008 | 07:12 AM
bigt's Avatar
boths yours are out of spec??? my trail rig i ran with tps unplggued runs fine but high idle....
i usually just go to the junkers and swap parts... but if i do by parts for electronics i would go toyota or napa maybe.. but im from canada you may have better options
Skinamer's Avatar
Just curious, why? I found A TPS at autozone that has a 2 year warranty and it says guaranteed to meet or exceed OEM specs and service life.
Old Nov 16, 2008 | 08:10 AM
mt_goat's Avatar
I guess for the same reason you bought a Toyota truck instead of a Ford Ranger. How long did the Toyota TPS last you? Like over 13 years probably? Do you want a part that may only last 2 years?
Old Nov 16, 2008 | 08:37 AM
Skinamer's Avatar
Good Point!!!
Old Nov 16, 2008 | 11:16 AM
Junkers88's Avatar
That explains why all my parts are busted.......
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
rjtrials
Aug 6, 2015 07:25 PM
bighaydn
Aug 4, 2015 07:17 PM
