Bad TPS?
Old Nov 14, 2008 | 09:43 PM
Bill54880's Avatar
Bad TPS?
I unplugged my TPS and other than maybe slightly more power and a slightly higher idle(+500) there is no difference in the way it runs. So is the TPS bad or is it good? Everyone says to run it without it to test it but now that I have what do my results mean?
Old Nov 14, 2008 | 09:59 PM
abecedarian's Avatar
I'd say test it:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Nov 14, 2008 | 10:08 PM
Bill54880's Avatar
I don't have the tools to test it. I've been told on here to unplug it and run it and then I'll know if its bad. So I did and its basically the same, which to me must mean that its bad because if its supposed to run the same with it and without it why would they put it on there, right? So...^ the question still stands, bad or not?
Old Nov 14, 2008 | 10:47 PM
874runnersr5's Avatar
pull the codes?
if it gives you the code, then look into it more.. if not, then its fine
Old Nov 28, 2008 | 09:43 PM
Bill54880's Avatar
I could do that too I guess but like I just asked, if it runs the same with or without the tps doesn't that mean that its bad?
Old Nov 29, 2008 | 03:16 AM
Bigblock's Avatar
What is the truck doing to make you think its the TPS?
Bigblock
Old Nov 29, 2008 | 06:28 AM
There should be a difference in idle tps unplugged
Old Nov 29, 2008 | 07:02 AM
dsmbuddy's Avatar
It wont run too different, most of the fuel calculations are done with the MAF.
Old Nov 29, 2008 | 07:58 AM
weaselman's Avatar
if your idel changed when you unplugged the tps. then it is working. your tps is fine. why are you checking ur tps. whats wrong?
Old Dec 1, 2008 | 05:00 AM
Bill54880's Avatar
If you see my other topics, I've been having some weak throttle response or overall lack of power along with occasional bogging or loss of power that happens after driving up a hill and lasts for a mile or two afterword. I've checked about everything and now I unplugged my egr vacuum line (and plugged it) and now it hasn't done it again. So now my question is why would disconnecting the vacuum line on my egr fix this problem. That must mean their was too much vacuum at the wrong times so what would cause that?
Old Dec 1, 2008 | 07:18 AM
werid. try cleaning the throttle body, i know after i did mine i gained some power actually. Run a can of seafoam to clean out the injectors?
Old Dec 1, 2008 | 07:19 AM
Bill54880's Avatar
I've done both.
Old Dec 1, 2008 | 07:27 AM
Tofer's Avatar
Sponsor
did you not get the memo about the new coversheets for the TPS report?
Old Dec 1, 2008 | 07:31 AM
fuel filter?
Old Dec 1, 2008 | 07:36 AM
4Crawler's Avatar
Well, your EGR modulator could be plumbed incorrectly or not working properly or the EGR valve could be sticking open or any number of issues there.
As far as testing the TPS, the "tools" to do so are very inexpensive, you can pick up a multi-meter for $5 or so:
- http://www.harborfreight.com/cpi/cta...emnumber=90899
and a set of feeler gauges if you don't have those you can use an old credit or gift card for the gap measurements.
Old Dec 6, 2008 | 05:06 PM
Bill54880's Avatar
Did the fuel filter.
Gone Fission
Jan 12, 2023 10:34 AM
Blamalam
Mar 12, 2022 07:34 AM
129Creepin
Aug 5, 2015 10:12 PM
Sidherish
Aug 3, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
