Will This Front Diff Work On My Truck?
Old Nov 12, 2008 | 04:58 PM
jdw1's Avatar
i have an 87 pickup ext cab with 22rec engine. found a front diff out of a 87 single cab pickup with a 22r engine in it for $100. will this diff still work even though the engines are different? also it came stock with 225/75R15 tires which is what mine came with.
Old Nov 12, 2008 | 05:16 PM
toyminator2000's Avatar
As long as the gear ratio is the same yes it will work. All 86-95 Toyota Pickup/4Runner front differentials re the same 7.5" Ring gear. Several Gear Ratio's were offered but the most common is 4.10.
Old Nov 12, 2008 | 05:18 PM
Just Learning's Avatar
it should 22re and 22r --ones fuel injected and ones carbed, the only difference may be the gearing, but i think it should fit, both are ifs
Old Nov 12, 2008 | 05:59 PM
89-4Runner's Avatar
yes
X2...
Old Nov 12, 2008 | 06:20 PM
DeathCougar's Avatar
Match the gear ratio, and you will be ok.
5sp trucks used a 4.10, Autos were 4.30. Simple as that
Old Nov 12, 2008 | 06:25 PM
jdw1's Avatar
thanks
saphirekosmos
Jun 22, 2015 10:26 AM
gog1968
Jun 22, 2015 05:55 AM
streetuner15
Jun 18, 2015 10:59 PM
TheManOutside
Jun 18, 2015 03:32 PM
