GlassPack!!
Old Nov 16, 2008 | 04:39 PM
Nothingbutyoda93's Avatar
Exclamation GlassPack!!
I want a new muffler for my 93 pickup
i want loud so im thinking a glasspack
but i dont know the size??????
the muffler i have on it now is welded on.
the owner b4 me put that on.
should i consider haveing it welded on like the old one
or just clamps and such
so i need to know the size of the muffler and how to install.
thanks yall
Old Nov 16, 2008 | 04:48 PM
toyota4x4907's Avatar
Heh. I'm in the same boat. My exhaust is leaking in between the ex manifold to downpipe, downpipe to cat, pipe to front of muffler and muffler to tailpipe. The biggest leak is from the pipe to the muffler. I still have the stock muffler though. What size are you asking about? I believe the stock piping size is 2" inside diameter, maybe 2 1/8. If you are asking about the length, then just measure whatever is on now and get that size and I would weld it on.
Old Nov 16, 2008 | 04:52 PM
what size tubeing, I dont have a welder so i guess im going to have to take it to a shop
Old Nov 16, 2008 | 04:53 PM
yoder519's Avatar
my buddy has a 91 nissan pickup 4cyl, he has the flowmaster 40 just like me and they sounded the same. then his pipe form the muffler back fell off due to a cheap muffler shop and it sounds awesome. im gonna do it to mine. and it dont sound like a ricer either
Old Nov 16, 2008 | 04:55 PM
so it has that more deep boom boom sound to it??
i talked to someone i know about a 40 and they said its not loud at all
i want loud but not sounding like a ricer
Old Nov 16, 2008 | 05:28 PM
4banginRunner's Avatar
i have a 40 series on my 22RE now..2.5" pipes after the cat, its loud, and obnoxious, deep tone not really ricery, more like a "flowmaster on a 4cyl" is what i've been told
i ran a 2.5" glasspack on both a 20R and 22RE....very loud, 20R was straight piped (header..18" pipe, glasspack, STRAIGHT pipe to the back)...set of car alarms and whatnot. 22RE was header, 2.5" pipe, hollowed cat, glasspack, 2.5" pipes out the back.....that was retarded loud, espically at 3500rpms+ set off alot of car alarms and had noise complaints from neighbors..
i'm out of the glasspack stage now that i drive to and from school/work everyday (50+ miles roundtrip)
Old Nov 16, 2008 | 05:35 PM
yoder519's Avatar
my tuck is quite with teh 40. i wish i hadnt got it. but i have 2iinch pipe.
Old Nov 16, 2008 | 05:36 PM
so what would you recomend i do
Old Nov 16, 2008 | 05:39 PM
yoder519's Avatar
well, like i said my buddies sounds awesome, with the 40 and no tailpipe. cheapest way would be to just cut off the muffler to make it louder, illegal, but louder. thats how mine was when i got it. it was loud. but not as loud as that nissan. but i had to buy a muffler cuz it wouldnt pass inspection.
Old Nov 16, 2008 | 05:42 PM
if you want loud go 2.25" or 2.5" glasspack
i've always clamped my mufflers on, since i change my exhaust setup alot
Old Nov 16, 2008 | 05:43 PM
Gokumono's Avatar
I was just about to make a post within the last day or so about what would be the best muffler to buy. Except i wouldnt want it loud. Im wanting a more quite but nice low sound to it. or deep sound i guess. :/
Sounds so far, if you want loud, glasspack. If you want more quite, flowmaster.
I have just a stock, with a hole in the bottom on the middle... Should probably get a new one.... but idk if its worth it yet.
What benefits have you guys seen with the new mufflers?
Old Nov 16, 2008 | 05:48 PM
yoder519's Avatar
i felt like mine gave me more power at first but it didnt. the benefit i got was my black powdercoated tip that looks sweet.. thats about it lol
Old Nov 17, 2008 | 02:54 AM
glasspacks....loss of top end power, loss of gas mileage, headaches
flowmaster...low end power improvement, when used with an air intake setup, it makes a smoother running engine
Old Nov 17, 2008 | 07:37 AM
93toyrunner's Avatar
Use a cherry bomb turbbo muffler or thrush turbo muffler, $20 at autozone, advance, or many other auto stores, sounds good, cheap, load but not annoying, and it is not just a pipe.
Old Nov 17, 2008 | 05:13 PM
Jay351's Avatar
I run a glasspack. I take my engine past 5,000rpm daily, I noticed a gain in mid-top end power.. Low end seems the same.. I like the sound, some don't...
Most people lose power because they will put a big pipe diameter on their truck (2.5"+)...
Old Nov 17, 2008 | 05:17 PM
cutboggers's Avatar
glasspacks are for tight wads or old fords.
buy a flowmaster or if your gash hurts get sumthing like a magnaflow or dynomax
Old Nov 17, 2008 | 05:20 PM
muddpigg's Avatar
DT header, flex joint , Hi flow cat, summit glasspack, and 2.25 ID pipe through. Love the sound not to loud but ricer like over 4000RPM (oh Toyota is a ricer duh). I like the set up,did most of the work myself. 22re's need back pressure so you'll suffer losses with too wide of pipe with no cat.
Old Nov 17, 2008 | 11:11 PM
Yotapowa's Avatar
Hey, I just installed a glasspack on my 86 22R. I used the stock pipe and cat up untill where the old muffler was, it was 1.75 inch. The glasspack was 2 inch, so i bought a pipe adapter, and i bought some strait pipe of 2 inch. So it goes 1.75, adapter to glasspack, then strait pipe no bends 2 inch diameter to the back of truck. I just used exhaust clamps, do em up real tight and it wont leak. Heres a video of my exhaust with it http://www.youtube.com/watch?v=OFO-93DGwlE
black_yota
34
Jan 23, 2010 01:54 PM
BigBoy60
Dec 11, 2009 07:24 AM
BS Industries
14
Apr 9, 2008 09:49 AM
taikowaza
Jul 18, 2006 11:33 AM
s0nic_strife
28
Jun 4, 2004 02:43 AM
