PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Idle surging at startup
  2. Fuel Filter, fuel pump, or catalytic converter? Or something else?
  3. Two Stage Thermostat
  4. broke camshaft why?
  5. Crap Idle after trans swap
  6. Speedo out 1991 toyota pickup
  7. 89 22r into 87 pickup
  8. 22re early to late intake swap
  9. Mistreated 94 pickup 3.0 4x4 manual
  10. 22RE plug identification
  11. How to refresh a throttle position sensor
  12. Top End Clatter at Idle
  13. Replacement of A/C Compressor, R12 to R134a
  14. Cheap leafs and tb crank?
  15. 1988 22r bogs at high rpms
  16. checking fuel pressure
  17. 3VZ-E Fuel Pressure Pulsation Dampener Repair or Delete updates?
  18. Plugged PCV Baffle on Valve Cover....Quick Temporary Fix??
  19. 22re 13mpg No low end Power
  20. Is this a leaking 22re head gasket?
  21. 1990 22re wiper transmission linkage replacement
  22. 88 Toyota truck 4x4 standard
  23. rear alignment?
  24. 1991 22RE- Who can tell me the difference between the 4WD and 2WD starters?
  25. 1990 22re into 1987 4runner
  26. Thermo-Tec Pipe Shield for Thorley Header - 3vze
  27. 1986 toyota 4runner
  28. 1988 22re efi truck 5" on 33" no power and running rich
  29. 22re fuel filter relocation
  30. 94 3zve pulsating while driving
  31. 1-2 shift fork
  32. swapping add diff to non add
  33. vafm setting for flamethrower injectors
  34. A couple engine questions
  35. 4WD rear mudflaps?
  36. 1990 toyota pickup 5.0 swap
  37. 93 4runner HID headlights
  38. A.D.D to Manual Question
  39. Power steering battle..
  40. 22re suddenly wont idle
  41. torsion bar adjustment
  42. 1995 T100 Runs rough after warming up
  43. 1990 4runner sr5 dash with oil pressure gauge cluster
  44. Help uninstalling chapman security system
  45. new car dilemma and toyota story
  46. 1990 DLX 3.0 Heater only working on low
  47. 22re won't idle when warm
  48. 93 pickup brake bleeding question??
  49. Stranded! - 22re Front Exhaust / Downpipe Removal + Reinstatement?
  50. T100 lift and tire fitment
  51. New 90; toyota owner...question about drivers window
  52. (another) shock question
  53. Loud ringing from 22re while running
  54. 3vze Engine Shudders and lost power.
  55. Seat covers for 1987 toyota extended cab
  56. 22R-TE Head Gasket Same as 22R?
  57. 1987 Clutch Master or Slave Replacement Question
  58. I found this lodged between my radiator and grill
  59. 22RE lower intake manifold removal
  60. 1990 toyota pickup 3.0 severe coolant leak
  61. another saggy rear- 93 pickup extracab v6 4x4
  62. 95 4runner 3.0 coolant temp Guage problem
  63. 22r running cold.
  64. 88 4runner evap emissions problem
  65. best bang-for-buck for servicing injectors?
  66. Is an Optima Yellow Top my best bet for a new battery these days?
  67. Coolant leak behind engine?
  68. Vacuum Switching Valve??
  69. Owner experiences with the V06 recall for 3VZ-E head gaskets?
  70. In desperate need of help troubleshooting 91 22re misfire...
  71. Extended Cab Roof Rack Install
  72. 87 22r miss
  73. Kickback cable-barely have reverse
  74. Someone please ID this undercarriage part for me?
  75. Hard start w/ low idle until revved, hot or cold
  76. 1'st gen 4runner QUICK fuel line/ FPR help! (Rich running issue)
  77. Got my 33's on!!
  78. AFM & timing setting opinions for 3vze -EGR deleted & flamethrowers
  79. fuel sending unit question
  80. 4runner 4.88 diffs in 93 pickup
  81. Brake Failure 94 Yota Deluxe
  82. No backup lights
  83. 1987 22re 4 runner help!!
  84. 88 toyota pickup 4x4 headlights
  85. Noise in 2wd goes away in 4wd
  86. 93 runner radiator questions
  87. Sudden Loss of Power - 1994 Pickup 22re
  88. is this chain/valve sound normal? I think not
  89. 1990 Toyota Pickup Won't stay in gear
  90. downsizing tire or adding a LSD
  91. 1990 22re pickup driver door manual window reguator
  92. 3vze Accidentally shorted diagnostics box!!!! HELP!
  93. opps !
  94. 92 yota steering box
  95. 1994 3VZE Transmission Help (1994 4Runner)
  96. 91 Pickup 4x4 not working
  97. Storing 3.0 with blown HG for the winter- tips please?
  98. 93 pick up, 22re, 2.4L - does not start
  99. Speedometer/Odometer
  100. Passenger Window mechanism
  101. 88 pickup with 22er and efi wont start
  102. '95 4runner rear bumper fit on '93 4runner?
  103. Golden cam lobe and 30# in cylinder 3
  104. Interior restoration almost done
  105. 88 pickup 22RE high idle after total rebuild
  106. My right side lower control arm is rusted thru, how do i replace?
  107. Chevy running gears in a Yota
  108. Lurching When in 4x4...?
  109. cylinder head
  110. Advice on my new 94' Toyota pickup
  111. cruise
  112. 22r into 20r
  113. Hard to start or won't start warm.
  114. 93 pickup not shifting through 3-4th correctly
  115. mk3 supra lsd install
  116. 22re missing and skipping
  117. R150 Rebuild Kit
  118. RPM drops!
  119. Torque wrench
  120. 22re pinging at high speed
  121. 87 toyota help
  122. what dipstick tube
  123. Acceleration stumble
  124. 95 4runner 3.slow surging idle
  125. hard start
  126. Anyone using a 1 1/16" bore mc in 1st gen. Rnnr
  127. Where to get parts for my 87 4runner?
  128. fuel tank removal
  129. 88 yoda sluggish acceleration
  130. 86 22re intermitent skip
  131. Help with 89 Toyota
  132. 1st gen 4Runner (89) brake upgrade question
  133. 88 22re starts but wont run
  134. 350 4 runner
  135. Brake problem- pressure then no pressure
  136. It's been covered. Time and time again. 22re oil pressure problem.
  137. Rear defrosted help
  138. 2nd Gen Roof Rail Bolt Help
  139. 86 ifs 4runner build
  140. 1.5" Body Lift - Now some issues
  141. The Knock Sensor from Hell
  142. Odyssey Battery Tray
  143. Roaring/grinding noise
  144. is this custom or no??
  145. Progressive failure of all electrics and lights, truck still runs
  146. Solid back window for a 1987 toyota 2wd
  147. What does your aftermarket oil pressure read @ idle
  148. 93 22re missfire
  149. 1993 toyota pickup receiver hitch
  150. Mystery plugs my wire harness where do they go
  151. '93 4Runner neighborhood crackhead cat delete
  152. Truck runs fine until warm
  153. Anyone know where to find replacement weatherstriping?
  154. Parts compatability
  155. 86 4runner 22re no heat
  156. my 93 3vze is getting horrible mpgs!
  157. TPS adjustment? Or throttle stop screw?
  158. Another 3.0 Head Gasket - Deck Heads?
  159. 140 amp underhood welder/ new charging system 88 truck
  160. just run electric fuel pump???
  161. Dash - where is the check engine light located?
  162. Coolant on Belts - 22RE - How to clean?
  163. eBay snorkel opinions
  164. Truck died
  165. '94 4x4 - hard starting when hot - bucking in 2nd gear
  166. Add Speakers Project
  167. Sledgehammer Mod
  168. 1994 Toyota 4x4 truck - dash panel / seat cover questions
  169. Which piston rings?
  170. 93 Toyota 4x4 saggy butt
  171. 1988 22RE diagnostic port pinout
  172. Ecu
  173. 1991 Pickup Transmission Noise?
  174. 4.3 swap
  175. Melting Battery Cable
  176. 1994 Water By-pass issue
  177. Left tail lignt only
  178. 22re Smoke Issues
  179. 3vz 3.0 rebuild
  180. AC clutch bearing question
  181. 22re misses at higher rpms, not at idle. tons of new parts.
  182. Need part # for this..
  183. Front Shock Recommendations: 1993 3.0 4x4 Ext Cab SR5
  184. 1990 toyota pickup running great then go out to work and no start
  185. tried every method of bleeding known to man still won't go into to gear
  186. 3rd gen Runner dash into a 1st gen
  187. Timing Chain Done - Gear Drive Sound
  188. 2nd gen 4Runner roof rack/cargo basket recommendations
  189. 1986 22RE O2 Sensor too long?
  190. Shock length?
  191. 1988 Leaf Springs
  192. installing a five panel wink mirror?
  193. Mysterious drivetrain(?) vibration
  194. Should I rebuild my 3.0?
  195. Anyone running a mechanical gauge ?
  196. Rear vent window - how easy are they to replace?
  197. Factory Engine Overhaul Gasket Set
  198. '90 4rnr 4wd auto mystery
  199. have spark / no fuel 89 pickup 3.0 runs for a 1/2 second then dies
  200. Added a center cup holder
  201. 2" lift w/o using body lift? 1991 ext cab
  202. timing belt not spinning 3vze (video inside)
  203. 1992 pickup wiring
  204. 88 pickup doors sometimes dont open from inside
  205. 1987 toyota pickup high temp/ smoking
  206. AFM problems!!! pulled the two.screws!!!
  207. IAC confusion
  208. The Possible Solution for 3.0/Auto Owners.
  209. Need help!
  210. What engine (if any) will bolt into my 91 4runner V6 3.0L 3VZE
  211. MPG help 1992 Toyota pickup
  212. 1992 Toyota pickup spedometer noise
  213. Was it worth 1300?
  214. 22re head
  215. 1990 front window trim
  216. 3.0td surf high rpm miss
  217. 95 Toyota pickup 22re bent valve
  218. Rear axle moved while adding a leaf..
  219. tranfercase locks ok tho front axle doesnt
  220. Tilt Install Problems...
  221. Installing power door locks on an 86
  222. 22re suspected headgasket
  223. Locker front or rear
  224. Mystery Oil Leak from 93 3.0 5-speed
  225. Need advice: 86 4Runner starting issues - fuel flow? fuel pump failing?
  226. Broken panhard bar/blown axle seal connection?
  227. 89 v6 3.0 rough running
  228. 3VZE weird noise and no start
  229. 5.3 swapped '93
  230. 2 odd probably not related issues with oil leak and loss of heating.
  231. Replacing Camshaft need help
  232. body lift for 86 4 Runner
  233. Need to replace taillights - can't get tailgate down!
  234. Anyone know which finishes were clearcoated on 86-88's?
  235. '94 pickup, 22re blew the timing chain, have some questions
  236. Sticking brake calipers!!
  237. Speedometer/Transmission
  238. Cost of going from stock to lifted.
  239. Sourcing front Parking brake cable '86
  240. My new 4x4 Labs rear 4Runner bumper
  241. 93 4runner suspension question
  242. Does anybody apply some kind of hi-temp sealant to exhaust gaskets?
  243. 1993 22RE 4x4 SB won't start hot
  244. 3VZE running hot, idling high after timing belt change
  245. Egr/pair vaccum issue, and a unidentifiable hose 95-4r
  246. cigarette lighter install question.
  247. Just bought a 86 yota and have couple ???s
  248. Dear Experts - where does this go?
  249. Calling soarerjzz30 (or others) - 87 Charcoal Gray 2nd Gen...
  250. 4runner diffs in pickup??
