A.D.D to Manual Question
Old Nov 16, 2014 | 10:09 PM
Hrddrvs's Avatar
In have a 91 truck V6(Auto)with A.D.D system.I dont want the driveshaft and CV axles spinning constantly.If I get a set of Aisin hubs from a 4runner and install,will that eliminate the driveshaft and cv's always spinning?I dont care about shift on the fly 4wd and dont mind getting out and locking them when I need 4wd.Is there anything else I have to do other than install the manual hubs?I searched but cant find an answer.Thanks for any information.
Old Nov 17, 2014 | 03:58 AM
BigBluePile's Avatar
Where did you search? I did one search in the googlez and came up with tons of stuff.....
Maybe this will help: http://www.4x4wire.com/toyota/tech/add/
Old Nov 17, 2014 | 05:06 AM
JasonYota's Avatar
Where did you search? I did one search in the googlez and came up with tons of stuff..... Maybe this will help: http://www.4x4wire.com/toyota/tech/add/
X2. Tons of info on this. Maybe searching means different things for different people.
Old Nov 17, 2014 | 07:16 AM
scope103's Avatar
Originally Posted by Hrddrvs
In have a 91 truck V6(Auto)with A.D.D system.I dont want the driveshaft and CV axles spinning constantly....
If your driveshaft is turning, the ADD is not working. What lockable hubs give you (other than another point of failure) is they disconnect the half-shafts from the wheels, so the half-shafts don't turn while in 2wd.
Old Nov 17, 2014 | 07:44 AM
JasonYota's Avatar
I still would rather have locking hubs than the ADD system. I don't see your point of "another point of failure". We get more questions about ADD problems than manual hub problems just saying
Old Nov 17, 2014 | 08:34 AM
scope103's Avatar
Originally Posted by JasonYota
I still would rather have locking hubs than the ADD system. ...
Hrddrvs wasn't talking about "instead," but "in addition to." If you're worried about the reliability of ADD (some are), you could probably lock it into "engaged" and use locking hubs. A permanently locked ADD might be more reliable than one that switches ... your choice.
If Hrddrvs's ADD really isn't working correctly, it might be worth understanding why. If it's already not working, there is no guarantee it won't get worse.
colasurdo
Jan 11, 2026 08:10 AM
jaretstuff
Aug 4, 2015 02:08 PM
TransAmBandit
Jul 28, 2015 11:30 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
