For those who manual swapped a 22RE 4x4...
Old Jul 26, 2015 | 03:09 PM
TransAmBandit's Avatar
I had a question regarding the flywheel and bell housing bolts. I remember reading they are the same as the flex plate and auto bell housing bolts. Now from my experience from manual swapping Supras and Cressidas they aren't the same.
I did some research on LCE's site on the bolt kits they offer. And it didn't specify if the flywheel bolts interchanged. It just listed them as compatible with the 22re.
I just picked up an 88 XtraCab 4x4 and I want to pull the auto out since I have mostly all of the parts already it's just the bolts I need to verify.
Old Jul 27, 2015 | 02:16 PM
wyoming9's Avatar
Red face
No flex plate bolts are much shorter.
With Flywheel bolts order then from the dealer There prices on hardware I think are reasonable.
Old Jul 28, 2015 | 07:34 AM
87hoerunner's Avatar
Wyoming9 is right bolts are shorter some people will argue that the spacer on the flexplate takes up the difference but it doesn't. Just done this swap a year ago
Old Jul 28, 2015 | 02:59 PM
Thank you for confirming this. I actually ended up accidentally stumbling upon a swap thread the night before where someone took a pic of the length differences.
87hoerunner, are the bell housing bolts lengths the same? The 4 main ones specifically?
Old Jul 28, 2015 | 07:01 PM
Yes bellhousing bolts were the same
Old Jul 28, 2015 | 07:14 PM
Thank you so much! Guess I'll order my bolts tonight.
Old Jul 28, 2015 | 11:30 PM
wyoming9's Avatar
Red face
Flywheel bolts are one of the few I put locktite on
Scary what a flywheel coming off can do to feet and legs.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
KBar
Jul 13, 2015 06:01 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
