93 pickup brake bleeding question??
Old Nov 16, 2014 | 06:19 AM
shepsyota's Avatar
Im in middle of 4runner diff swap to 4.88's. Front is done. Im in process of rear, im only undoing the brake line behind each backing plate and park brake cable just to get axles to slide out enough to remove carrier. Where and how is best way to bleed once im back together? Thanks!
Old Nov 16, 2014 | 08:10 AM
Teuf's Avatar
Start with the rear passenger wheel / rear driver / front passenger / then front driver.....Pump hold bleed, repeat. Keep reservoir full. This is a 2 person job.
Old Nov 16, 2014 | 08:33 AM
shepsyota's Avatar
Ok, wasnt sure if i could get by just bleeding the rear. Didnt know i had to bleed front to. Thanks!
Old Nov 16, 2014 | 10:46 AM
wyoming9's Avatar
Red face
Where still debating that ourselves some say it is not needed others say it is go figure
Old Nov 16, 2014 | 04:17 PM
hiluxhack's Avatar
Bleed the rear and see if the pedal is firm. When in doubt, bleed it out.
Old Nov 16, 2014 | 04:26 PM
shepsyota's Avatar
Haha i like it. Im not off till friday and weather depending if ill get to finish, cause im doing it in my driveway. I'll bleed rear first and see what i got. I'll let you guys know the outcome as soon as i do. Thanks!
Old Nov 21, 2014 | 01:55 PM
shepsyota's Avatar
Just finished the rear swap. Bled just the rear brakes and have perfect pedal. I put a peice of rubber hose on end of each brake line so it wouldnt leak out fluid, after i reinstalled we old fashioned pumped and bled each side 3 times and she was ready to go!
GreenLion
Jun 7, 2021 10:49 AM
LV_4Runner
16
Aug 5, 2002 11:35 AM
jalaber
Jul 24, 2002 06:48 AM
Lowviz
Jul 22, 2002 10:52 PM
