Top End Clatter at Idle
Old Nov 19, 2014 | 04:27 PM
Nelsen Motorsports's Avatar
I am a pretty experienced mechanic and acquired my first Yota last week (traded a rusty Benz diesel for it) and it has been a blast other than fixing the surging idle. Today I noticed some noise in the top end.
I pulled the valve cover off and the chain guides have been upgraded to steel, so that isn't the problem. Everything looked clean so I put it back together. The noise is still there and it exists at only idle-1200 rpm or so (I need an SR5 gauge cluster lol).
I am thinking that I may need to adjust the valves. The truck has no blow-by and no smoke upon start-up so it probably isn't valve guides. Like I said, this is my first 22R-E so I am taking everything into account. The engine has had a recent rebuild and everything is clean, the rockers aren't even oil stained.
What is your experience?
Old Nov 19, 2014 | 06:03 PM
rworegon's Avatar
Hi, welcome aboard.
Valve adjust just might do the trick. Some do say these sing like a sewing machine.
Give the Advanced Search under Tools on the tool bar above a try.
Old Nov 19, 2014 | 06:34 PM
Hugh_Mann's Avatar
I've checked and adjusted mine a couple times in the past few months and I still have a loud one on the intake side. My plan is to go a hair tighter than factory to quiet it down when I get around to it.
You'll hear different advice on valve lash adjustments... Some say you can do it cold, others say go a bit tighter than stock, even both. You might find though, that setting them to the stock gap produces a lot of clatter. Either deal with it or set them tighter, but at your own risk!
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
Iceman4193
Jul 15, 2015 04:48 PM
crashburnoveride
Jul 10, 2015 06:39 AM
