Dash - where is the check engine light located?
Old Oct 28, 2014 | 05:02 PM
Josh_Br's Avatar
Hello,
I have a 1990 Toyota pickup, 4x4, 22RE. It has no factory tach. Please tell me where the check engine light is located. Mine does not work at all, and I would like to check the bulb.
Thanks,
Josh
Old Oct 28, 2014 | 05:30 PM
thefishguy77's Avatar
By does not work at all you mean you have not seen it? Or do you mean that you jumped the diagnostic ports and got not CEL?
Old Oct 28, 2014 | 05:31 PM
RJR's Avatar
RJR
On mine it's in the lower right corner of the instrument cluster.
Old Oct 28, 2014 | 05:35 PM
Josh_Br's Avatar
Bottom right - thank you.
It does not light at all, like it's burned out or something. It doesn't come on when you turn the key or when you jump the diagnostic jumper.
Old Oct 28, 2014 | 06:08 PM
Josh_Br's Avatar
Got it - the bulb was missing. Good to go now. Thanks
Old Oct 28, 2014 | 06:30 PM
RJR's Avatar
RJR
Glad you found the problem. Someone may have removed it if it was annoying them.
Old Oct 28, 2014 | 10:33 PM
scope103's Avatar
Originally Posted by RJR
... Someone may have removed it if it was annoying them.
Yeah ... like "sure is annoying that no one will buy this truck with the CEL on."
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
