Cheap leafs and tb crank?
Old Nov 19, 2014 | 12:17 PM
Tenn87pickup's Avatar
Wanting to lift my truck alittle bit and fit 33's. Any suggestions on brands or kits?
Old Nov 19, 2014 | 04:31 PM
highonpottery's Avatar
there really aren't any "cheap" leafs that are worth buying. expect good leaf packs to cost around $150/side, excluding the bushings kit and shackles if you need those too. t-bar crank is free, just remember to get alignment after to correct camber.
one of the top brands for leafs across the globe is the ARB/Old Man Emu Dakar leaf springs. They come in medium and heavy duty. HD is more for fully-loaded safari rig and is quite stiff I hear. Medium ends up settling to lift about 2" over stock height. On my 93, it was quite a big jump initially, when compared to saggy-butt it was previous, but settled nicely. Ended up at 22.5" in rear (center axle to bottom of fender) with stock shackles.
front end you can do t-bar crank of stock t-bars, stiffer/thicker aftermarket t-bars, bj-spacers, and bracket lifts to gain height. generally you have around 0-3" you can adjust with t-bars and/or bj-spacers. bracket lifts are a fixed 4", but you can still play with t-bars after.
research here on YT in the IFS lift guide.
Old Nov 19, 2014 | 04:35 PM
Alright Thanks for the quick reply and a lot of valuable info man. I'll keep everyone updated when I get a plan!
88sasturbotoy
Jan 30, 2026 01:57 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
TJWilly
Jul 31, 2015 02:05 PM
redneck17
Jul 17, 2015 07:44 PM
Nickdigg
Jul 7, 2015 06:04 AM
