1992 pickup wiring
Old Oct 22, 2014 | 11:38 AM
h_louviere's Avatar
1992 pickup wiring
Hello all. I recently purchased a 1992 extra cab 4x4 3.0 with manual tranny. And I'm just beginning to try and work out the kinks. First question is about the wiring for the oil pressure sending unit. It does not operate at all. I know I have oil pressure. And I have installed a new ops. I can not find a wiring diagram for the ops. Does the wire go from ops to ecu or straight to gauge? Any help or links to help would be greatly appreicated.
Old Oct 22, 2014 | 12:26 PM
scope103's Avatar
The ECU doesn't care what the oil pressure is; this is strictly a gauge item.
I assume the "ops" means Oil Pressure Sensor. I also assume you got the one for the gauge, not the idiot light (if you use the latter sensor it will destroy the gauge). The wire from the sensor is Yellow-Blue, and connects through harness-harness connector ID2 (pin 15) under the passenger kick panel.
Old Oct 22, 2014 | 01:17 PM
h_louviere's Avatar
Yes I got the one for the gauge. How do I know where those pins are? The only yellow/wire is on the middle plug on one of the corners. Does that sound right?
Old Oct 22, 2014 | 01:38 PM
h_louviere's Avatar
Sorry I just realized you said harness to harness connector. Is that behind the ecu?
Old Oct 22, 2014 | 01:44 PM
scope103's Avatar
I'm relying on a wiring diagram; it only shows it as in the same corner as the ECU. behind/next I don't know.
Old Oct 22, 2014 | 03:19 PM
h_louviere's Avatar
Where did you get that diagram? Can you send me a link or something?
Old Oct 22, 2014 | 04:10 PM
scope103's Avatar
https://techinfo.toyota.com/techInfo....toyota.com%2F
A two-day subscription is $15.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
toyota32
Jul 6, 2015 05:42 PM
colinmil
Jul 6, 2015 04:03 PM
wilbertd
Jul 6, 2015 07:39 AM
