4runner 4.88 diffs in 93 pickup
Old Nov 12, 2014 | 04:25 AM
shepsyota's Avatar
Ok im currently swapping diffs in my 93 pickup, with 4.88 ones i got out of a 94 4runner. My question is when swapping the axle tube on driver side because i have manual hubs, did anyone add an oil seal in there cause the 4runner diff doesnt have one on that side or just swap tube and go? Thanks!!
Old Nov 12, 2014 | 06:36 AM
Yotard's Avatar
are you switching from an add diff to non add or from non add to add? It depends on which way you are going.
Non ADD axle seal goes here on the diff: (IGNORE the finger pointing, you can see the seal on the diff)
If you are running ADD, no seal there so that the ADD actuator and stub axle gets oil:
bigger view of the ADD axle without the seal.
Old Nov 12, 2014 | 12:20 PM
shepsyota's Avatar
Yes im putting a non add tube on a 4runner diff that had add.
Old Nov 12, 2014 | 12:21 PM
shepsyota's Avatar
I pulled the add actuator out and was wondering if i needed to install a seal before installing my non add axle and tube
Old Nov 12, 2014 | 12:32 PM
Yotard's Avatar
yes you do just like the top picture
Old Nov 12, 2014 | 01:06 PM
shepsyota's Avatar
Awsome. I thought so but wanted to make sure before i put it together. Thanks. Are the axles usually stiffer going back in, they poped right out of carrier but test fitting back, they didnt want to just slide in.
Old Nov 12, 2014 | 01:59 PM
Yotard's Avatar
yeah that spring C clip has to compress, just give a good whack with a dead blow and it will pop back in place.
vasinvictor
Jan 20, 2016 12:39 PM
Valvoman
Jun 28, 2015 02:45 PM
Niameyrider
Jun 25, 2015 05:50 AM
P51warrior
