22R-TE Head Gasket Same as 22R?
Old Nov 15, 2014 | 07:51 AM
franssell's Avatar
Hey is there any difference between a head gasket for a 22R-TE and a 22R or 22RE?
Old Nov 15, 2014 | 11:43 AM
wyoming9's Avatar
Red face
Depends just how much boost are you running ??
Any special machine work done to the head.
If it is all stock the head gasket is the same not sure if the complete head set is different though
Old Nov 15, 2014 | 03:21 PM
franssell's Avatar
Its the standard EFI Turbo that came stock with the 1987 pick up. No special machine work. I changed the head with a brand new one and a new gasket and the the head is still leaking like a sieve.
Old Nov 16, 2014 | 03:26 PM
wyoming9's Avatar
Red face
I will bet you under torqued the head bolts.
65 foot pounds
Get a new gasket and try again
Old Nov 16, 2014 | 06:27 PM
franssell's Avatar
65 foot pounds
I torqued them to 58 foot pounds, do you think it would have made that big of a difference?
Old Nov 16, 2014 | 06:56 PM
franssell's Avatar
Is it common for the block to be warped at all?
Old Nov 16, 2014 | 10:40 PM
wyoming9's Avatar
Red face
I did one over 10 years ago only torqued to 58 foot pounds coolant just poured out new gasket retorqued to 65 footpounds still going strong.
Heads tend to warp before blocks. takes a lot of heat to warp a block
Old Nov 17, 2014 | 05:04 AM
franssell's Avatar
Yep, that sounds like what happened to me as well. I ordered a new gasket and bolts, I'll let you know how it goes! Thanks!
kgcwb44
Jan 29, 2023 10:02 AM
cars-guy
Aug 16, 2020 06:59 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
