Brake problem- pressure then no pressure
Old Nov 3, 2014 | 08:04 PM
Longo118's Avatar
Hey Guy,
This thread is going to sound silly but I literally have run out of ideas as to what is causing problems with my brakes.
1987 pickup
A few weeks ago I replaced my rear axle. I hooked my old brake lines up and noticed I have no pressure at the brake pedal. I replaced a ton of brake line, my bleeder valves and the master cylinder and still have the same problem. I can press on the pedal when the truck is off and the pressure is great but once the truck turns on the pressure goes away and won't stop the truck.
I adjusted the brake shoes, gravity bled the lines, got a vacuum pump and bled the entire line out of air but still have the same problem. I disconnected the booster to see the vacuum pressure and the booster works great. It's been 2 weeks of brake work on this truck and still no progress. Any help would be greatly appreciated!!
Thank you
Old Nov 4, 2014 | 03:00 AM
PapaChulos4U's Avatar
I have only been able to successfully bleed the brakes while the truck is running and someone is assisting. Can you use the vacuum pump while the truck is running or get someone to help out?
Old Nov 4, 2014 | 05:30 AM
Longo118's Avatar
Yea I tried it. There was some air coming out of the line but overall it still wasn't a hard pedal
Old Nov 4, 2014 | 05:50 AM
muddpigg's Avatar
Sounds like a bad mc. Swap it out.
Old Nov 4, 2014 | 05:52 AM
Longo118's Avatar
I did again last night. I put in a refurbished one and last night I bought a brand spanking new one And put it in. And still no luck
Old Nov 4, 2014 | 06:53 AM
muddpigg's Avatar
Then brake booster.
Old Nov 4, 2014 | 08:07 AM
Innocent Fool's Avatar
Sounds like you might have the lines to the lspv mixed up
Swap the two lines around and try again
Old Nov 4, 2014 | 10:28 AM
X2
Also check the MC. If you got one from Advance/AutoZone, then chances are you got garbage. I live in Roanoke, VA where Advance is HQed, and I HATE their parts
Old Nov 4, 2014 | 05:32 PM
Longo118's Avatar
X2 Also check the MC. If you got one from Advance/AutoZone, then chances are you got garbage. I live in Roanoke, VA where Advance is HQed, and I HATE their parts
I had a refurbished one but went out and decided to buy a brand new one afterwards. I didn't touch any of the lines in the engine bay, only the rear brake line on the axle and the one under the cab going to the MC
Would a squishy pedal be the booster though?
Old Nov 4, 2014 | 05:42 PM
85TurboRunner's Avatar
what order did you bleed the brakes in?
Old Nov 4, 2014 | 06:08 PM
Longo118's Avatar
I started with farthest to closest. And after I redid the master cylinder a few times I switched it up to closest to farthest and farthest to closes again. I've been doing these brakes over and over again for 2 weeks and still can't get pressure
Old Nov 4, 2014 | 08:00 PM
nothingbetter's Avatar
when you did you bleed the lspv in that sequence? you do know you have to bleed the lspv right?
Old Nov 5, 2014 | 10:10 AM
Longo118's Avatar
The ISPV being the rear one on the frame? That was deleted And cut off from the previous owner. Or is there another one I am missing?
Old Nov 11, 2014 | 10:22 PM
that is the only lspv. How are your lines being ran? One MC port to the front, the other to the rear? Any inline manual proportioning valves installed? Do you have the required residual valves in your mc? factory size calipers/drums?
Old Nov 12, 2014 | 12:26 AM
wyoming9's Avatar
Red face
Booster does not effect pedal only the effort to push it.
Your getting air back in the system some place or your rubber brake hoses are swelling up under pressure.
Poor connection will allow air back in.
Then maybe your rear shoes are not adjusted up enough or the drums are worn over size .
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
94ofCanada
Aug 14, 2015 06:37 AM
calderp
Jul 27, 2015 09:58 AM
CanRunner
Jul 20, 2015 01:29 PM
