- Did some work to my runner
- Removing front sway bar for desert running
- Help a noob out here
- wire speedo cable after 5spd swap??
- 95 4runner lift questions
- 3.slow WONT START!!! HELP!
- sputtering 22re
- New 285/75r16's!
- Where to mount?
- 22re running/ starting issue
- jerky coast to throttle
- Anyone ever put in a stage 1, 2 or 3 chip into an 88 4runner?
- Just a quick question, regearing absolutely needed?
- 22re vapor lock?! HELP!
- Ready to lock it....or am I??
- exhaust leak and dash insert?
- Alternator Upgrade?
- My truck won't start and other issues
- I need some help here!
- Rear left corener (driverside) bed is hot from the exhaust
- What Kind of Plugs do Yota like?
- Tax Return!, Time for Mod$!
- Ball Joint Spacers - 86 4runner
- abnormal clutch wear?
- 2WD Spring Swap
- Lesson for the day. Never trust the seller.
- New 94 standard pick up owner
- 93 3vz-e Rebuild
- '89 4Runner 3.0 3VZE Dropped Valve Seat
- 3.0 v6 or 2.4 22r
- my new (to me) Pickup
- I want a lift
- Spring Break Project
- Is the 22RE slush box really that slushy???
- Torsion bars / Lift
- 89 3.0 Runner Code 25 26 Pressure On Fuel Cap
- Fuel Economy** LINK**
- Front wheel noise when cold - 90 SR5 4WD
- 93 lift help appreciated
- Steering Wheel Shakes
- clutch an p plate question
- 1988 Toyota pick-up won't idle
- add-a-leafs on 88 4runner
- new 35's, new to me anyways
- So I swapped in a rebuilt 3.0 this weekend
- New rebuilt 3vze v6 idle bounce
- Vacuum Hose connections to Throttle Body
- 22re exuast question...
- Lift kit questions
- where does the plug go?
- No Reverse 91 PU 3.slow Automatic
- Tightening seatbelt return spring
- Like marbles in my engine
- custom "oh crap" bar?
- Help Help Help : Runner Parts
- Starting to get non-starting frustrations...
- engine knock- Valves or Timing?
- For one day, I had a nearly perfect garage!
- What Tires should i buy for my 2wd Runner?
- Common spots for Power Steering leak? Help
- just showin off the new rims...
- My luck has recently changed!!
- Why does 22RE have such a good rep. when they suck!
- Swapping 3rd's, Will It Work?
- hella h4 conversion kit...
- 2wd torsion bar install **LIFTED**
- 3VZE Timing Belt Running Crooked
- Blower motor Q's.......
- Bumper compatibility
- Is my timing chain shrinking?
- More pics of new truck
- any pictures of your pu lifted with stock wheels?
- duelie 4runner?
- '91 Pickup Clutch Cable???
- rancho upper control arms
- rancho upper control arms,ifs
- Anyone want solid axles?
- Torque Converter
- Who runs with welded rear on road?
- reasons to buy marlin crawler bumpers (pics)
- who makes a good fitting seat cover?
- LEDS!!!! what kind
- wiring Problem. 88 body on 94 chassi
- Been a while since I've posted...here's a "Did you Know...?"
- downey slip yoke half shafts for ifs
- major brake problems
- ADD to Manual hubs...parts needed
- finally took some pics
- 89 runner wheeling pic
- 1987 Pickup Shock options
- brake system question
- Newbie with oil leak update
- Timing Idler pullys of something in that area
- The swampthing2 killed in action...
- 1986 Brake Problem: Fading Brake Pedal
- Need Parts List
- Will a newer Rad fit my 87 4runner
- Power Steering Pump Interchangeability
- 3.4 Swap shops
- Eliminating Rusty Wheel Wells
- my truck wont run right help!
- my truck has wont run right help!
- 4runner on the rocks, stock rig advice
- looking for Roof Rack info
- One Cylender not wanting to fire on start-up? Shaking on startup then goes away.
- Vaccum Lines
- Got some work done on the runner
- Mk2 --- 84-89
- ID your PickUp & 4Runner & Hilux
- Newbie Question: 1st gen 1989 4-runner
- Someone help me with my TPS adjustment
- Fuel tank issues...
- Question about small lift to run 33x12.5. BJ spacers + 1" body lift
- Running pig rich, get a code after sitting for a long period
- alternator belt
- i need 1 ton axles any ideas?
- Bracket lift (Rancho) + BJ spacers?
- Newbie with oil leak 89 truck V6
- 94 toyota pickup has no reverse light
- Torsion bar adjustment 91 PU????? Too stiff!
- IFS Suspension Rebuild - IT HAS BEGUN!!! PICS!!!
- Check Engine Light
- crush sleaves
- Just bought a boat, need your advice!
- Headlight electrical issue - please help
- 4runner voltage numbers. Abe?
- Front axle nut socket
- lockright or leave open?
- a340h auto solenoids???
- key wont turn. how do i remove ignition?
- IFS front pinion seal leak!!! rebuild???
- Newb and TN Refugee
- Pinion Seal
- selling a 2nd gen 2door
- think I found the issue with the shudder from start.
- If you don't get accurate TPS readings...
- HELP: Fan Pulley Bracket
- Rear defrost suddenly stopped working
- Bogging down
- stuck questions
- Creative ideas for my 4.10 front diff
- NWOR 3vze Headers
- land cruiser axle sas ???
- Question about 4runner diffs
- Videos
- Please Help!!! 91' 4runner Clutch is making me do a work out!
- 22re idle stop screw setting
- 1992 4x4 extra cab
- pulling motor
- 22re wont start
- pull the + cable and the truck dies, alternator?
- 1990 4runner rear coil lift questions
- Transmission Terror.. 3rd and 4th went out.
- 86 4runner auto 22re Got three issues
- Blown motor / transmission mount? What do you think?
- Fixing a stupid mistake: 20R back to 20RE
- Speedo calibration for 91 PU
- R.i.p 86 4runner - Vancouver, wa, anyone need parts?
- Will a canopy off of a Taco fit?
- Looking for engine swap options
- Nicest Runner I've EVER Seen
- gearing ?
- Pre-Planning for this weekend's work
- Rear 3erd in front?
- Exhaust Pics?
- need help what trany is this?
- LSPV bad maybe? Thoughts?
- best way to rust proof your undercarriage
- water pump failure ???
- Belts on a 3.slow...
- rust spots on bed
- what size tires?
- driveshaft question
- 1 Can of paint plus 30 mins ====??
- 1989 4 Runner 22RE running very badly
- Exhaust setup questions
- 1987 4Runner with 20r. Which head Gasket?
- Trying to order a marlin clutch?
- To paint or not to paint???
- LC Engineering Header 22RE
- 3.0 vze overheating starts 35 miles after swap
- Headbolt Torque Specs? 93 3.0L
- 92 3.0 clutch issue on startup
- looking for a snorkel
- 1986 Toyota Pickup 22r 4spd cutting out
- Anyone build a decent front skid?
- anybody have an upper ball joint not intstalled?
- 86 p/u 22r te won't rev over 2,000 rpm
- lower ball joint
- chassis bits and running gear (aka: Hooray)
- Creeper Joints vs Napa U-joints
- Which bolt triggers the ability to roll up rear window on 1st Gen Runners?
- K&N filter question
- water leak behind the motor
- K&N intake.
- Steering Wheel Shimmy at 30 MPH
- What's this connector go to??
- Cutting Donuts with 35s
- clutch/electrical issue- 87 4runner
- Rear Leaf Springs - 1993 Ext. Cab 4x4
- 86 4x4 transmission problems
- tips on better searching this site/backspacing question
- Steering assembly re-build, need advice!
- Where are the torsion bars?
- LC Engineering Power Packge upgrades...
- opinion on bulkparts.com solenoid kit?
- Radiator fix or tires - need some advice
- running rich
- Ring and Pinion, Locker Questions from Germany
- Cleaning rust out of engine
- Blown Head Gasket?? 1991 22re
- Engine wont start after swap. Electrical
- major engine problem
- Starting a build of a 7mgte
- rough idle when warm
- topper(camper chell) keep or sell?
- 22re Engine troubles
- It's Alive!
- Will 16.5x10 wheels fit w/BJ spacer?
- Brake Wear Denial
- Leaking Head Gasket
- New Radiator... New Problem
- Looking for exhaust shop around Boulder CO
- Need rust help with my 4runner
- Need Advice on Winch Installation, Suspension, Bumper -- Thank You All
- Headlight Ground?
- I had a reality check today about my pickup...
- cant find a diff breather.
- toyota pickup offcamber pic
- 1990 Toyota 4x4 Idleing problem
- 22RE 1990 Toyota Fuel Injector Replace - Help
- 4runner shut off
- Manual hub removed&reinstalled-now LOCKED always!?
- 89 4Runner with really weak front heat, but blazing back heat. Why?
- buying another yota
- exhaust smell source
- Swap advice needed
- Sickest deal ever...
- I need help ready to give up. Carb questions.
- has anyone built their own center console? lets see them pics....
- cone filters vs airboxes (comparison with support)
- 3.0 Knock Sensor
- Look what came out of my fuel filter
- cold start dead cylinder
- v6 vacuum lines
- Moog Balljoints problem
- Which 3.0 to put in my rig?
- auto tranny problems
- oil pump drive gear broke in half??
- 83 thirds in 90 truck
