86 4runner auto 22re Got three issues
Old Mar 5, 2009 | 02:24 PM
GNICTRY's Avatar
Question 86 4runner auto 22re Got three issues
1) in the am i turn the key in my 86 4runner,auto,22re and nothing no sound no cranck just silent. Turn back and back on and nothing for around 3-5 times. What could that be?
2)Rear window flood does not come out. Front works and rear wiper works. Just not fluid. What should i check?
3)Rear defrost does not work. What do I need to check or test?
Old Mar 5, 2009 | 02:29 PM
waskillywabbit's Avatar
1) Lights come on? Dash lights come on? Battery? Alternator? Starter?
2) Bag is in the driver rear, probably empty if it even still works at all.
3) See below for all of these.
http://www.4crawler.com/4x4/CheapTricks/index.shtml
Old Mar 6, 2009 | 06:31 AM
GNICTRY's Avatar
not sure on lights...do not believe dash lights worked but radio does...
thanks for reply ill check bag and look at link.
Old Mar 6, 2009 | 06:39 AM
GNICTRY's Avatar
great link but not see anything on defrost for rear...saw wiper/relays/lock...
Old Mar 6, 2009 | 06:48 AM
gohawks's Avatar
The opening and closing of the gate has more than likely cause the wires to break. Take access panel off. I believe there is another smaller panel to access the rear defrost wires. Open and solder them back. Worked for me.
Old Mar 6, 2009 | 07:08 AM
GNICTRY's Avatar
ill check that tonight thanks!
Old Mar 6, 2009 | 01:50 PM
GNICTRY's Avatar
i am not to electrically inclined...ill try to get my bf to look...
also ment to ask is it normal when shifting from park to drive or reverse...shift hard and jerk forward(drive) and backwards(reverse)
Old Mar 7, 2009 | 02:31 PM
gman62's Avatar
Ignition trouble
For what it's worth I encounter an intermittent failure of ignition when turning the key at times. Frustrating until I figured out there is a parking switch (auto transmission) that sometime doesn't get engaged fully when gear shift is in park. Wiggling the gear shift while in park and turning the ignition will determine if that is your problem.
1986 Toyota 4-Runner Auto 22RE
Old Mar 9, 2009 | 07:31 AM
GNICTRY's Avatar
tried that not seem to change anything...
now i have trouble starting period...like no gas..adjust idle n checked timeing
Old Mar 9, 2009 | 08:16 AM
raydouble's Avatar
Starter solenoid doesn't have to "click" to be the contacts.............mine did nothing when you turned the key and new contacts fixed it.
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Not saying it is your problem but definitely something to check out.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
noahstancik
Jul 10, 2015 11:18 AM
TNRunner88
Jul 1, 2015 08:00 PM
WI Girl
Jun 25, 2015 03:45 AM
bobbybouche
Jun 18, 2015 10:22 AM
