crush sleaves
Old Mar 6, 2009 | 03:35 PM
arizonaguy's Avatar
crush sleaves
once a crush sleave has been crushed and installed into a rebuilt differential isnt that the point of preload, once it is smashed and you can feel the wrench or breaker bar get easy to turn. Then why couldnt a guy just say thats the point of preload and if he had to take appart the diff for some reason when putting it back together re-use the crush sleave as if it was a solid spacer. I dont under stand, i mean when you put it back together you can feel the way the bearing turns inside the race, its preaty obvious when you have no more slop in the assembly. A dude could even go past this point slightly and then re-stake the nut, as far as im concerned. Hell tack weld the SOB!!. Right or no??
Old Mar 6, 2009 | 03:43 PM
waskillywabbit's Avatar
http://www.4x4wire.com/toyota/tech/crush_sleeve/
Solid pinion spacers work better.
Old Mar 6, 2009 | 09:00 PM
ZUK's Avatar
ZUK
You must have been reading my site
94toyy
12
Sep 14, 2015 06:18 AM
skoti89
Sep 11, 2015 07:46 AM
Randomness
7
Sep 29, 2005 11:04 AM
neil_P_smith
Jan 16, 2005 03:23 PM
FireMan
May 1, 2004 02:53 AM
