No Reverse 91 PU 3.slow Automatic
Old Mar 9, 2009 | 08:45 AM
DDias78's Avatar
I went wheeling this weekend, and while I was on the trail, my reverse quit working. (Had to get pulled out!). I searched the threads, and all I could find were threads on a manual transmission. My truck is a 91 Pickup 3.0 with an automatic trans. All of the other gears seem to work fine, and engage properly. When I shift in reverse, its just like being in neutral, the truck just revs. I was on a pretty rough trail w/ manzanita bushes everywhere, and I think some got under my truck. I'm thinking it might be the the linkage for the shift lever position? Anyone have any ideas?
Thanks,
Dave
Old Mar 9, 2009 | 08:54 AM
mt_goat's Avatar
Yeah start by getting under the truck and looking at the linkage. Does it go into "park" ok?
Old Mar 9, 2009 | 09:03 AM
DDias78's Avatar
Shifts into Park just fine. I just bought the truck a couple months ago, and am just familiarizing myself. I don't see anything unusual, but not sure what unusual might look like! Guess I'm just hoping I won't have to rebuild tranny.
Old Mar 9, 2009 | 09:39 AM
mt_goat's Avatar
I guess if it will shift into park it would also shift into reverse since reverse is between drive and park. Probably not the linkage in that case, unless its just not stopping in the right spot for reverse. Does the little red indicator show its in reverse, you know that little spot of color right by the letters P-R-N-D-2-1?
Old Mar 9, 2009 | 02:57 PM
DDias78's Avatar
The little indicator works, but I did notice a TON of play in my shifter. Thanks for the replies Dale!
Old Apr 19, 2009 | 03:40 PM
jgajardo2's Avatar
Dave, did you ever figure out the reverse problem? Same thing has happened to me on my 95 4runner 3vze engine 4wd.
Jim
Old Apr 20, 2009 | 07:25 AM
DDias78's Avatar
I did figure it out...I burned out the reverse power band. The bummer about these transmissions is that they are a pain to rebuild and very expensive to replace new. I opted to do a 5 speed swap and am accumulating all of the parts necessary to do so. The other option was just to pick up a used transmission for as cheap as possible. The A340H is integrated with the transfer case, which doesn't give you the option adding a crawl box, or basically do anything else to it. So for me, I am done messing with it! Going with an R150F and a gear driven t-case. So far I'm into it about 1200.00 and I have all of the major components, including a freshly built transmission. The cheapest rebuild at a shop I could find was 1900.00.
Old Apr 20, 2009 | 07:55 AM
mt_goat's Avatar
Originally Posted by DDias78
... The A340H is integrated with the transfer case, which doesn't give you the option adding a crawl box, or basically do anything else to it...
Are you sure about that?
http://www.pirate4x4.com/forum/showt...fer+case+mount
Old Apr 20, 2009 | 08:01 AM
DDias78's Avatar
Wow. I stand corrected! Pretty cool. All of the research I read said that you can only adapt to a A340F. Even so, I wouldn't mess with this transmission anymore! I like the simplicity of the manual.
Old Apr 20, 2009 | 09:57 AM
jgajardo2's Avatar
Thanks for the quick reply Dave! I was afraid of that, and whats worse is that I had that transmission rebuilt just 3 years ago! I'm also going to start looking into converting to a manual and gear T-case.
Old Apr 20, 2009 | 10:04 AM
small town BIG TOYS's Avatar
Convert it to a 5 speed. You can't wrong with a 5 speed.
Old Apr 20, 2009 | 10:15 AM
DDias78's Avatar
Sorry to hear that about your tranny Jim. 3 yrs ago? Wow, that sucks. Good luck on the swap, I should be knee deep in mine within the next couple weeks. If you search the threads around here you'll find some killer info, not to mention guys like Mt Goat that'll correct you when you need it and help you out when you need it!
Old Apr 21, 2009 | 09:07 AM
jgajardo2's Avatar
Sure will...I also just had enough with the A340H trans.
Old Apr 21, 2009 | 09:10 AM
jgajardo2's Avatar
Thanks Dave. I'll certainly convert to manual hopefully sometime soon. Do take some pics of your conversion as it happens. It will be great help and information..
Old Sep 28, 2022 | 06:30 AM
Kalepotter93's Avatar
Same problem
I'm having the exact same issue with my 91' 22RE automatic RWD.
Drives fine going forward, but sometimes it's hard to get into reverse; last night I couldn't get it to go into reverse at all.
Really hoping I don't have to put a new tranny in, but sounds like I'm going to😑
Thanks for all the info everybody!
And good luck with your trucks🤙
Truckwithoutaname
Oct 3, 2015 03:41 PM
Flightguy
Oct 2, 2015 05:34 PM
bradahman
Oct 1, 2015 09:24 AM
tshort48
Sep 27, 2015 01:04 PM
May-39
Sep 6, 2015 01:05 PM
