Is my timing chain shrinking?
Old Mar 8, 2009 | 11:33 AM
laughinm3's Avatar
So I will try to make this as short and sweet as possible. I recently blew a headgasket... and when i went to remove cam gear all i had to do was just tap it off with a rubber mallet. Fast forward a little bit... torqued the head down and my sprocket is about the width of the dowel to short. After reading the manual I have found that possibly by moving the crankshaft it might let some slack out, no dice. So what is going on here the engine is a rebuild with 30k on it and I have not lost timing. Any ideas? thanks
Old Mar 8, 2009 | 02:20 PM
annoyingrob's Avatar
Tensioner.
Old Mar 8, 2009 | 02:21 PM
laughinm3's Avatar
so what needs to happen?
Old Mar 8, 2009 | 07:29 PM
874runnersr5's Avatar
you need to take off the timing cover and replace the tensioner. Might as well replace the timing chain to. Pretty easy
Old Mar 8, 2009 | 09:52 PM
85TurboRunner's Avatar
You have to push in the tensioner. Just reach something down the front of the engine like a long screwdriver and push it in and pull up on the cam sprocket, it should slide right on.
Old Mar 8, 2009 | 10:06 PM
DeathCougar's Avatar
What he said
Without that tensioner pushed in, you won't be able to get the chain on correctly.
Old Mar 9, 2009 | 03:10 PM
laughinm3's Avatar
thanks much
Old Mar 9, 2009 | 03:40 PM
Flash319's Avatar
Be careful though. You can damage the tensioner.
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
razorman8669
Jul 12, 2015 12:13 PM
