Belts on a 3.slow...
Old Mar 4, 2009 | 07:20 PM
Squeebs's Avatar
Any tricks to speed up the process?
I've never done it on this particular motor, but its usually a 20 minute job if everything goes wrong from experience on other motors
I'm gonna do mine this sunday.... any tricks to make it smoother?
Old Mar 4, 2009 | 07:27 PM
abecedarian's Avatar
20 minute job if everything goes wrong?
I wish I could change all of the belts on my 22RE in 20 minutes- the alternator always gives me fits.
Old Mar 4, 2009 | 07:37 PM
gary96360's Avatar
its so easy doing the belts if you dont have a/c. looks like last owner got rid of the system . i just use a stick to tighten the belts and i hold it at the same spot to tighten the bolts.
Old Mar 4, 2009 | 07:44 PM
Squeebs's Avatar
Most of the newer cars im used to doing them on.... its just one big ol' belt.
maybe im spoiled and will actually have to put some time in effort into this one.
Old Mar 4, 2009 | 08:18 PM
to quote guns n roses, from "welcome to the jungle"
"...my... my... my serpentine...."
Old Mar 4, 2009 | 08:21 PM
xzyragon's Avatar
its even easier without a flywheel....
but ya, i have the world record in changing belts...
3 1/2 minutes
then again, i was missing the entire front of my car when i did this
Old Mar 4, 2009 | 08:49 PM
Tubbyfatty's Avatar
i hear removing the fan helps, i havent looked in to it that much but i want to do that when i change mine soon.
Old Mar 4, 2009 | 08:57 PM
toyota4x4907's Avatar
flywheel is in the rear...
xzyragon's Avatar
last time i checked, its nearly impossible to change them without moving the fan
Old Mar 4, 2009 | 09:00 PM
Its actually quite easy to do it with the fan on
chadsturbotoy's Avatar
HAHAHAHAHAHAHAHAHAHAHA!! THAT IS SO FUNNY! omg! my girlfriend is looking at me strange cuz i just cracked up laughing for like 5 minutes! haha best joke EVER!
my buddy has the 3.0 and he always struggles with the power steering belt.. wait.. maybe it was the A/C belt.. well.. one of those two is the tricky one.
haha..my serpentine.. lol..
Old Mar 4, 2009 | 09:03 PM
turborich's Avatar
I changed my belts a month ago. No need to remove the fan at all. I took off the upper portion of the fan shroud & not even sure if I needed to do that. You will need to loosen the alternator bolts , power steering pump bolts & the A/C belt will come loose with the idler pulley on the bottom. It's actually very easy but looks like it would be a PITA! The belt will slip right over the fan.
Good luck
Old Mar 4, 2009 | 09:04 PM
turborich's Avatar
You beat me to it.
Old Mar 4, 2009 | 09:06 PM
Good luck
on the 3VZE?
Old Mar 4, 2009 | 09:10 PM
You beat me to it.
I did I was talking about a 22re though...I have no idea about a 3.0L...Xzyragon was talking about a 22re so I was replying to him
You don't have to loosen the PS pump..theres an idler/tension pulley on that system (22re)...
Old Mar 4, 2009 | 09:11 PM
xzyragon's Avatar
fine, i admit that i was wrong
my apologies
its probably even easier on mine, i dont have AC or PS
Old Mar 4, 2009 | 09:14 PM
i thought you might be talking about the 3vze, and was getting confused. i just wanted to clear that up
Old Mar 4, 2009 | 09:19 PM
by the way what part of Alaska are you from. my girlfriend is from there and we are going up there this summer. are there any trails or anything for my stock toyota pickup around the Anchorage area?
Old Mar 4, 2009 | 09:52 PM
blacklabel's Avatar
I did the belts on my truck a few months ago. its a '92 3vz v6 w/o A/c
the belts slide over the fan without removing anything at all.
loosen up the alternator and the power steering pump and remove and replace. it helps to have a friend that can hold the tension on the alternator and ps pump while you tighten up the bolts, so you get good tension on the belt.
I had both changed in 10 mins.
Old Mar 4, 2009 | 10:31 PM
turborich's Avatar
yes the 3VZE V-6. It looks tougher than it is. You can do it!
