add-a-leafs on 88 4runner
Old Mar 9, 2009 | 11:50 AM
e-hut7's Avatar
Hey yall, i am getting ready to replace the seals on the axle and was thinking about fixin the sag with some add-a-leafs. i was wondering which brand is recommended, and are there any issues with add-a-leafs that i should be aware of? thanks in advance.
Old Mar 9, 2009 | 08:41 PM
treknwil's Avatar
I have Pro comp AAL. No issues with them. They did the job.
Here's a pic of the install, if you look close you can see it between the overload spring and the spring pack.
Old Mar 9, 2009 | 08:45 PM
4banginRunner's Avatar
Depends on how sagged your OE springs are, AAL didn't do much for me, only barely got the pack off of the overload. Flexed like crap, and rode worse.. for me at least. I ended up doing my own ZUK mod, then later went with 63s. Night and Day
New springs, ZUK mod, 63" Chevys, 57" Fords are all better options IMHO
Old Mar 9, 2009 | 08:49 PM
4Crawler's Avatar
The Rancho Soft-Ride AALs are a good option, too:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ14
What you want to avoid with AALs are ones with a single short, thick (stiff) leaf. Those can cause the existing leaves to get stressed and bent over the end of the stiff AAL and that can damage the rest of the spring pack. So you want to use an AAL that is not much thicker than the rest of the leaves. The Rancho kit is nice in that it comes with a longer and shorter leaf that you can mix-n-match with the existing leaves to get the ride height and quality you are looking for.
Another option below:
- http://www.gearinstalls.com/dc.htm
Old Mar 9, 2009 | 08:51 PM
874runnersr5's Avatar
I went with downey springs.. so far they are amazing.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
