Bogging down
Old Mar 6, 2009 | 04:03 AM
rockb1's Avatar
Bogging down
Here is what i have. Rebuilt 22re, the build was just done. I notice that while accelerating in 3rd gear the truck seems to bog down. I am unable to put as much pressure on the throttle as I am in the previous gears. Every gear after seems to have the same power which seems low. What should I be looking for? What could the possible problems be. I know that this motor isnt a huge powerhouse but I know it should have more power than it does. Thanks for the help and advise.
Old Mar 7, 2009 | 03:15 PM
abecedarian's Avatar
double check the timing is set properly (with the jumper in the diagnostic connector and the TPS adjusted correctly) and that the valves are all set correctly (.007/.008 intake and .011/.012 exhaust with engine warmed up)
MadMax48
Mar 3, 2020 10:33 AM
TACOJO
Nov 27, 2015 05:26 PM
oldpickupguy
Sep 1, 2015 05:46 AM
