22re running/ starting issue
Old Mar 10, 2009 | 03:34 PM
bikerbob's Avatar
TO start off I have had random rough starts over the last 6 months. After the truck was warm and I would stop for a short time, less than 30 min , the truck would start but idle low about 400 rpm and be really rough. It didn't always happen. I never looked into it because if I gave it a little gas and then drove off it went away. There were no engine code at this time.
Fast forward to the last 2 weeks and I have had a similar issue.
First I got engine codes 4 and 7.
I replaced and adjusted the tps and the code 7 went away. I found a frayed wire on the coolant sensor right on top of the thermostat housing. I need to clear the codes again to see if the code 4 goes away.
I am still having a starting problem thought. It fires right up and idles @ about 900-1000rmp for about 1 sec then goes to about 400 rpm and gets slower till it dies. It will do the 5-6 time before it idles normally and warms up @ about 900 rpm. It only does it when the engine is cold. What should I check now?
Old Mar 10, 2009 | 03:50 PM
Flash319's Avatar
I would change your circuit open relay. Sounds like your fuel pump is shutting off. Also check the operation of the flapper in the AFM and make sure it moves easily.
Old Mar 10, 2009 | 03:54 PM
ampMX's Avatar
good luck
Old Mar 10, 2009 | 04:37 PM
Flash319's Avatar
Originally Posted by ampMX
well if it has a idler control motor id check that. if not then maybe your motor is running too cold? so maybe the thermostat is stuck open.
What the??
sonic concepts
Aug 16, 2025 03:13 PM
Sandman
Jul 23, 2015 08:15 PM
puffin04
Jul 10, 2015 09:17 PM
slider417
Jun 22, 2015 10:18 AM
bobbybouche
Jun 18, 2015 10:22 AM
