PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 [233] 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Elocker help please.
  2. wiring problem
  3. squeaky clutch- HELP
  4. 5.0 Swap
  5. Should I sell my 95 limited?
  6. Toyota Factory Alarm Key FOB
  7. is it a g or a w?
  8. 10W30 or 40?
  9. replacing rotors on a 91 runner
  10. Looking for a wiring harness for an 89 Runner
  11. ebay performance chip
  12. Towing capacity on 91 runner
  13. What would it take?
  14. 3.0 Header overheating...why?
  15. New Toy-------- (pics)
  16. hood compatibilty?
  17. Identifying EFI fuel tank?
  18. Electric fan options
  19. 5 days good then overheat...
  20. Dropping my 86 runner
  21. Complete SAS swap for sale
  22. flat bed or custom bed
  23. Broke down!!!
  24. Vibrating and rattling unengaged...
  25. 93 spring project
  26. any good clutch writeup's
  27. Truck for sale in VA
  28. 22RE main bearing question
  29. fj80 tie rod ends taper
  30. 5 blinks, then 6.. then pause
  31. bouncing speedometer
  32. whats the stock gearing on an 86 runner?
  33. half door question
  34. Mazda Spring swap? How many done it?
  35. Growing Power Stearing Leak
  36. solid spacer with locker install?
  37. I don't know where these plugs go..help!
  38. installed new O2 sensor still have problem
  39. new hitch install ..
  40. So I'm going to lunch at work yesterday when....
  41. 94 4runner is running rough
  42. '87 22RE, starts & runs fine then dies after 10 min---2 codes
  43. anyone done LC engineering upgrades?
  44. 96 Tacoma hood on a 95 4runner?
  45. HOw do i replace head gasket?
  46. 1994 4runner stock speaker sizes & upgrades? - searched
  47. '87 Yota won't start
  48. 89 3.0 clutch woes
  49. ARB or E- locker,and ARB question
  50. New Guy Asking For Opinions
  51. Replacing Vacuum hoses.. what sizes and how much
  52. Tailgate on ebay
  53. What a PITA!!!!
  54. Would you buy this 4runner?
  55. Anyone used Comp Cams on 22r?
  56. Need help with wiring in a Mallory Hifire 6-AL
  57. 86 4 Runner, slapping sound under hood?
  58. Sounds like a belt slapping?
  59. difference in beds?
  60. Anyone have a spare IFS axle nut and a transfer case bolt?
  61. 1988 Xcab rear speaker install question
  62. '87 pickup question
  63. Will not start after head gasket change
  64. Help with hose!!!
  65. This is cool , if you have not seen it
  66. hood scoop intake
  67. Exhaust stud hole stripped
  68. Finally Got my new 02 sensor in!
  69. Rear spoiler to keep exhaust out (4Runner)?
  70. Body Lift on and **PICS**
  71. 84 to 88 gauge cluster upgrade??
  72. Windex
  73. TPS or Timing?
  74. does anyone know (drips from tail pipe)
  75. 87 hilux
  76. I Hate Electrical Problems!
  77. Broken 1st gen rain gutters
  78. Not good news
  79. Spark Plug Problems
  80. fuel pump fuse
  81. 2007 taco rims on a 94 4runner
  82. Amp problems
  83. Anyone mount lights on rear fin before?
  84. 400.00 for an arb bumper a good deal?
  85. Knock Sensor?? EGR?
  86. Help indentifying a few electrical connections.
  87. Dimmer switch
  88. "My engine is smoking please help"
  89. Detroit trutrac questions
  90. 92 4x4 Persistant Overheating
  91. For those who have Borla exhaust
  92. Finally Got My New Tires On!! Pics
  93. Brush guard
  94. Gurgling sound from AFM
  95. 3 Quick Questions (with pictures)
  96. Difference between a cracked head and a blown HG
  97. Little Help needed with rough running 3vze
  98. Timing chain replaced, awful sound
  99. Caling all St. Pete manual trans experts
  100. Head bolt washers
  101. Racing Seats?
  102. got an ECT mod copy?
  103. valve covers warped?
  104. 87'22re to 93'22re swap
  105. 22r turbo upgrade?
  106. New paint job.
  107. Oil light/ Rough on startup
  108. New timing chain = Increased Oil Consumption?
  109. Restored 86-95 steel rims for sale
  110. Total Loss of Power when truck warms up. Help!!!
  111. How long do bottom ends on 3.0s last?
  112. Sold the Lolly Wagon!
  113. Skinnier tires, better ride?
  114. confirm this
  115. More info on clutches for 89 4runner requested.
  116. UCA's and LCA's
  117. need a new engine
  118. Welding onto the "downpipe"
  119. 22RE Distributor and EFI gas tank ident. =p
  120. 5w30 to light?
  121. Code 5...02 sensor signal question
  122. #4 Injector leaking (spraying)
  123. ????hard water deposits on windshield????
  124. 2nd gen Pickup Flat-beds.
  125. Can brakes un-warp?
  126. How is the 2nd gen auto antenna supposed to work?
  127. Brakes started acting funny...
  128. EFI fuse
  129. Fuel Pump Question
  130. good child safety seat for going off-road?
  131. Power Steering help!!
  132. Short shifter
  133. Wheel backspacing?
  134. crossmember drop as a lift?
  135. 22r questions
  136. Only Driver PW works, nada from others
  137. play in steering
  138. Exhaust help / ideas for 88 P/U
  139. Shifter bending? and 33's on stock frame...
  140. brake job lessons learned
  141. 20r
  142. 2nd Gen 4Runner Rear Upper Shock Brackets
  143. Engine won't stay running
  144. Bad fuel injector... 3 months old...
  145. Problems Starting My 87 4runner
  146. 22r or 22re
  147. Possible to mount a roof rack to a 1st generation without drilling holes?
  148. 94' put in new long block, now it won't start
  149. 3rd Gen coils on a 2nd Gen???
  150. Engine Machinists talk
  151. what's a good tonneau cover for '94 pickup?
  152. WabFab Wheels Spacers Arrived!!!
  153. Losing water and oil
  154. '93 2L-TE overheating need HELP PLZ
  155. New to me 4Runner have some questions
  156. umm....what is this thing i found in my truck?
  157. Question: 4" lift + 32" tires?
  158. '92 Tacoma Info Needed.
  159. 87 22re 4Runner exhaust (CA)
  160. Suspension Lift Checklist
  161. spare tire carryer and nerf bars
  162. rust bucket
  163. what offset are you running
  164. what is the easy way to pull the starter?
  165. custom 2nd gen
  166. Ford Van springs???
  167. ball joint spacers / body lift or crank the t bars?
  168. Top End Assembly
  169. need a toyota parts guy to hook me up!
  170. Speedo quit working. 93 pickup.
  171. how to change idle???
  172. My truck, 88 Runner
  173. Had TPS replaced, now code 7, runs bad
  174. Inexpensive LT upgrades to IFS
  175. 22R Intake manifold stuck
  176. Looking for info on New Rims and Tires for my 88 pickup. What do you think?
  177. I'm just at a loss now
  178. Back Door Light Disable
  179. Speaking of "balancing" your motor.....
  180. e.f.i vs carb while 4x4in
  181. 93 pickup problems
  182. 93 pickup oroblems
  183. shocks & bj spacers ?
  184. Auto Tranny Compatibility
  185. Changed my rear shaft's ujoints today.
  186. offer for 4900
  187. I guess im just stupid
  188. 87 4 Runner, Fuel Pump Goes Dead
  189. Help!! Can't figure out parts...
  190. How to remove hose at back of engine
  191. 95 3VZE - Dropping Oil Pan Helpful Hints
  192. PICS Look y'all - Katie got a truck maybe she can have a 4wd runner now!
  193. What are some good spark plug wires?
  194. Side Window
  195. 93 Truck - constant one power to radio
  196. 4runner Borla Exhaust Clearance
  197. Brake Light is always On
  198. cam gear hits metal cover?
  199. new imco muffler job
  200. Lock Out swap
  201. Black diamond body lift
  202. shifter issues in 86 5spd tranny
  203. Nothing says summer like......
  204. Need help, charging problem
  205. new locker behavior
  206. Headers
  207. brake issues
  208. 22re connecting rod, upper bushing/bearing
  209. Help!!!
  210. my new 88'
  211. Critique my (future)setup...
  212. 1990 4runner 3.0 auto - oil gauge testing 101
  213. factory sunroof questions
  214. 1st Gen 4Runner Tonneau
  215. new toyota click after lift install
  216. Pickup With Cab Mounted Safari Rack?
  217. Look what the previous owner left for me in the oil screen
  218. Optima battery mounting
  219. Oil presure
  220. Front Range Off-Road Fab Severe Use front Bumper?
  221. Rear Spring Bolts
  222. Aftermarket Oil Pressure Guage Install ?
  223. Fan Removal kickin my butt!
  224. Starting issue
  225. How do I measure for lift kit
  226. Need Help installing suspension on 94' 4Runner
  227. idler arm has lots of play mech said...unsafe
  228. This engine bottom end stuff is getting confusing.....
  229. Locking gas door 2 gen 4wd pickup
  230. squeaky clutch but only when cold
  231. 94 4runner bogging down
  232. Budget center console
  233. Preparing for a road trip
  234. 2nd gen 4Runner atuo to anual swap.
  235. Good deal on 3vze 3.0?
  236. Coolant Sensor
  237. need help fast!!!
  238. :/
  239. 1988 4 Runner Top has rusty trim pieces
  240. My 3vze is a dog, any ideas?
  241. Good deal on 1994 4Runner?
  242. 86 4Runner Temp
  243. timing chain replacemnt
  244. Odometer electric on a 92?
  245. Tailgate removal
  246. Artic 4Runner on 44s
  247. Cheap center link quality
  248. subwoofer mod in 90-95 4runner storage compartments
  249. What shock length?
  250. 3vze to 22re Swap
